opaque windows in vector view
akscott
yep - I'm working with ancient  version 10. XP operating system....  only one of my many saved plans has the transparent windows. I have tried 3D>3D settings>options>vector view options> check opaque glass from outside.
6 hours ago, rgardner said:
Didn't use it back then but can you just change the window glass to white or gray instead of glass?
For such an ancient application I think Ryan's suggestion is the best you will find. I used versions 4-10 but my memory is not that good. My version 11 Or X1 will run only in XP x32 and currently my XP hard drive is not working. Try that and see if that does not "solve" your "problem"
