rwdozier Posted January 11, 2021 Share Posted January 11, 2021 Am I missing something about intersecting wall doorways? Framing seems to be ok, but I still have something in the doorway in 3D view. Thank you. Untitled 1.pdf Untitled 1.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 11, 2021 Share Posted January 11, 2021 Not ideal, and I typically don't recommend using this method very often, but I think the quickest and easiest solution is probably to just break the Wall Polyline in 3D somewhere in the middle of that door opening and drag the bottom so that it's up above that other opening. Just remember you did that because the wall bottom will no longer automatically adjust for certain plan changes. 1 Link to comment Share on other sites More sharing options...
rwdozier Posted January 11, 2021 Author Share Posted January 11, 2021 Link to comment Share on other sites More sharing options...
rwdozier Posted January 12, 2021 Author Share Posted January 12, 2021 Ok, Thanks! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 12, 2021 Share Posted January 12, 2021 FWIW, you will need to have a king post & header above the doorway to support the beam. Check with your engineer. Link to comment Share on other sites More sharing options...
stephenbc Posted January 13, 2021 Share Posted January 13, 2021 10 hours ago, Joe_Carrick said: FWIW, you will need to have a king post & header above the doorway to support the beam. Check with your engineer. Maybe that beam is supported on the other wall beyond the opening. Link to comment Share on other sites More sharing options...
rwdozier Posted January 13, 2021 Author Share Posted January 13, 2021 13 hours ago, solver said: A pony wall works too -- Room Divider on bottom. Use a Wall Cap to cover the exposed framing. Thanks guys! This method meets my needs well. And yes, I always consult with an engineer for any concerns. Thanks again. Link to comment Share on other sites More sharing options...
