QualicoreHomes 3 Posted December 31, 2020 Hello, Not sure if this possible but I am trying to show how far a roof has to be removed for a renovation job. I thought to use a vector camera view and add some notes overtop in the layout. I am trying to place a piece of glass at the point where they have to stop removing the existing roof. I have the same material as the windows of the house which are see through but the separate piece of glass remains color filled. Is it possible to make it see through? I just want to have the outside lines showing. Thanks for any help! Share this post Link to post Share on other sites
solver 1636 Posted December 31, 2020 Seems like what you have would be far more clear than a couple of hard to see lines. Did you search before asking? Something like vector clear? Share this post Link to post Share on other sites
QualicoreHomes 3 Posted December 31, 2020 I searched "Glass Vector View" but have to admit didn't look close enough . When I searched vector clear I came across the tread "Can a Material Be Nothing?" where you wrote about making a new symbol without a panel which sent me in the right direction. I ended up making a symbol so it looks like it is glass. Thanks for the help!! Share this post Link to post Share on other sites
MarkMc 540 Posted December 31, 2020 Not sure what you're after. Guessing it's an addition? in which case perhaps a 3D reference view with some creative layer settings. Here made the addition Glass house and referenced the as built set to standard. On the addition plan the first shows only walls and roof, second shows only attic walls and roof, third only attic walls. Share this post Link to post Share on other sites
Joe_Carrick 2362 Posted December 31, 2020 Another option would be to use the "Cross Section Slider". Share this post Link to post Share on other sites
QualicoreHomes 3 Posted December 31, 2020 5 hours ago, MarkMc said: Not sure what you're after. Guessing it's an addition? in which case perhaps a 3D reference view with some creative layer settings. Here made the addition Glass house and referenced the as built set to standard. On the addition plan the first shows only walls and roof, second shows only attic walls and roof, third only attic walls. Yes it is an addition but part of the overhang has to remain so I was looking for a way to illustrate that in the demolition plan. Thanks for the replies Mark and Joe! Share this post Link to post Share on other sites
