divreig Posted December 18, 2020 Share Posted December 18, 2020 I have imported the loading doc roof I did in sketch up the, the structure is 3852" wide . Chief imports the correct size, but then when i try to move it up to the correct height chief shrinks the imported roof structure to 3000". I did not find any limits on imports on the docs or help. Anyone ells had this problem? existing model.plan existing roof only.skp Link to comment Share on other sites More sharing options...
Mark3D Posted December 19, 2020 Share Posted December 19, 2020 can you upload sketchup file then i can try reimporting it Link to comment Share on other sites More sharing options...
divreig Posted December 19, 2020 Author Share Posted December 19, 2020 Thanks ! file attached existing roof only.skp Link to comment Share on other sites More sharing options...
Mark3D Posted December 19, 2020 Share Posted December 19, 2020 Its working but i have no idea what fixed it it may only be tempory have a look 1152103210_existingmodel.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 19, 2020 Share Posted December 19, 2020 There does seem to be some sort of limit. I've seen this behavior manifest itself with minimum sizing but this is the first time I've seen it with maximum sizing. The problem isn't actually triggered by moving the object. It's triggered by opening the Fixture Specification dialog and doing anything except hitting Cancel. You just have to move it without using Open Object. Use either Transform Replicate or Move in an elevation. You should also report to Tech Support. 1 1 Link to comment Share on other sites More sharing options...
divreig Posted December 20, 2020 Author Share Posted December 20, 2020 Thanks to you both. !! Link to comment Share on other sites More sharing options...
ACADuser Posted December 26, 2020 Share Posted December 26, 2020 That's an easy build in Chief. Why use SketchUp Link to comment Share on other sites More sharing options...
