HaroonMalik Posted May 20, 2021 Author Share Posted May 20, 2021 Hi Eric, Can you please help me to find the solution for area calculation macros in both imperial and metric formats in similar fashion for closed poly-lines as well? Link to comment Share on other sites More sharing options...
HaroonMalik Posted May 20, 2021 Author Share Posted May 20, 2021 Hi Eric, Can you please help me floor wise schedule. For example three different schedules for three different floors. By the way I found the solution for my last question. %area.to_sq_m.round(2)% sq m Link to comment Share on other sites More sharing options...
Doug_N Posted May 20, 2021 Share Posted May 20, 2021 Just adding a bit for the area macros, if you make the label with a global variable in it you can use that variable to do statistics, like for example construction area. %$room1=room.standard_area.to_sq_ft.round(2)% sq ft Now the variable $room1, will have the value of the area of that room. if rooms 1 and 2 are the rooms where construction occurs, and the building permit is based upon room size them construction area will be %$room1+$room2% Just a trivial example I know, but it works wonders for doing lot statistics with building areas, hard and soft landscaping, lot coverage and the like. Link to comment Share on other sites More sharing options...
HaroonMalik Posted May 20, 2021 Author Share Posted May 20, 2021 Hi Doug Norton Thank you for your help. I am a BCIN designer too. Working in Peel region most of the time. Can you please share CA file to explain this. This looks very interesting if we can figure out the lot coverage, hard and soft landscape %age, Site area etc. I desperately looking for this solution. Looking forward for your help. Thank you and best regards, Haroon Malik Link to comment Share on other sites More sharing options...
Doug_N Posted May 20, 2021 Share Posted May 20, 2021 8 minutes ago, HaroonMalik said: Hi Doug Norton Thank you for your help. I am a BCIN designer too. Working in Peel region most of the time. Can you please share CA file to explain this. This looks very interesting if we can figure out the lot coverage, hard and soft landscape %age, Site area etc. I desperately looking for this solution. Looking forward for your help. Thank you and best regards, Haroon Malik Here you go. This is a typical project with site statistics. The variables are used in the plan file and in the layout files Garage Oakville.zip Link to comment Share on other sites More sharing options...
HaroonMalik Posted May 20, 2021 Author Share Posted May 20, 2021 Thank you very much! Let me explore it tomorrow. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 28, 2021 Share Posted May 28, 2021 interesting technique, took me a bit to find it... defining the global variable right in the label: " Proposed Garage Garage Area = %$gasf=area.round()% %$ga=(area.convert_to("sq m")).round(2)% m² " I never thought of doing it that way. I was always calling a macro to set the variable. Doing it the way you've done it means no macros Thanks for the insight. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 28, 2021 Share Posted May 28, 2021 4 minutes ago, jasonn1234 said: Doing it the way you've done it means no macros FWIW, it wasn’t actually even possible prior to X12. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 28, 2021 Share Posted May 28, 2021 is there a way to "find" variables. I was hunting and pecking looking for" $ga" in the layout and the plan. the search/ find tool in CA doesnt seem to find it. IS there another way? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 28, 2021 Share Posted May 28, 2021 What do you mean by “find”. Are you trying to remember where you put the text? Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 28, 2021 Share Posted May 28, 2021 well in this case it was not my plan (and there are actually two linked plan files), so I had to go looking. It turned out to be on the redrawn plot plan. I figured maybe you knew an easy way to find them :o). But your line of thinking is probably a good one, what are the chances of one forgetting where one put them....probably low. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 28, 2021 Share Posted May 28, 2021 8 minutes ago, jasonn1234 said: I figured maybe you knew an easy way to find them :o) I do. I was just trying to figure out more specifically what you were hoping to accomplish. You could have been talking about finding where you defined it, finding where you have displayed the value, finding the actual vale itslef, etc. etc. If you're just looking for where the text has been used you should be able to simply use the Find/Replace Text tool. Just make sure under Macro Options that its set to Include All and don't include the leading space before the text like you did above... 42 minutes ago, jasonn1234 said: I was hunting and pecking looking for" $ga" in the layout and the plan Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 28, 2021 Share Posted May 28, 2021 I mistyped in the post above I was looking for $ga but I did not check the macros...interestingly it is not actually in a macro (which is where I looked originally, macro management). I just tried and sure enough if you check macros it finds it. Thanks! some other tidbits in case others find this post...from the user doc: Find/Replace Text and Spell Check locate text in Rich Text, Text, Callouts, Markers, CAD blocks, schedule titles and headings, and custom labels for objects and rooms. They do not locate text in automatic object labels, default room labels, suppressed labels, the Materials List, or in schedules, however. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 28, 2021 Share Posted May 28, 2021 14 minutes ago, jasonn1234 said: interestingly it is not actually in a macro (which is where I looked originally, macro management). That text encapsulated with percentage signs IS a macro. Link to comment Share on other sites More sharing options...
Doug_N Posted May 28, 2021 Share Posted May 28, 2021 11 hours ago, jasonn1234 said: interesting technique, took me a bit to find it... defining the global variable right in the label: " Proposed Garage Garage Area = %$gasf=area.round()% %$ga=(area.convert_to("sq m")).round(2)% m² " I never thought of doing it that way. I was always calling a macro to set the variable. Doing it the way you've done it means no macros Thanks for the insight. Just for information, there is more than one way to convert values, for example in place of %$ga=(area.convert_to("sq m")).round(2)% m² you could also use %$ga=(area.to_sq_m,round(2)% m² and as Michael pointed out, anything between the % symbols is actually a macro, but it is not a recorded macro that you can reuse by calling its name, because you have not named it. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 28, 2021 Share Posted May 28, 2021 4 hours ago, Doug_N said: because you have not named it. reminds me of this....: https://www.youtube.com/watch?v=na47wMFfQCo :o) Link to comment Share on other sites More sharing options...
