TommyHarris Posted December 8, 2020 Share Posted December 8, 2020 Im trying to make a brick eave/rake as shown in the detail. Any help would be much appreciated. Link to comment Share on other sites More sharing options...
joey_martin Posted December 8, 2020 Share Posted December 8, 2020 Use that detail to create and save the brick corbel to your library and use a molding polyline to place it on you plan. Same for the fascia board. A 3D molding line will give you the finish at the bottom, the crown can simply be added as a "shadow board" in the roof dbx. 1 Link to comment Share on other sites More sharing options...
ShaneK Posted December 8, 2020 Share Posted December 8, 2020 If that detail is a photo, import it, scale it to size and trace it in a CAD detail 1 Link to comment Share on other sites More sharing options...
TommyHarris Posted December 10, 2020 Author Share Posted December 10, 2020 Thanks for the help. So I got the brick molding the way I needed it, but now I'm trying to get the curve in the eave. any advice? Link to comment Share on other sites More sharing options...
GeneDavis Posted December 10, 2020 Share Posted December 10, 2020 What curve in eave? Your detail depicts a frieze board with a flared bottom end, the flare having a radius cut at its inside edge. That flare detail can be done with a p'solid, begun by taking a CAD detail from the elevation, then drawing the shape, etc. The crownmold rake with return at bottom is tricky. Not the crownmold, but the return. Consider making it as a solid, then do it as a symbol, and place it. Link to comment Share on other sites More sharing options...
