shallow box window
GintOtis
How do you guys recommend i build this first floor box window?
(it would only project 6" from face of brick, and bottom edge would not align with floor)
hint, using CA's 'box window' is not it...
Thanks!
-gint
OK... more specific questions to my window:
My situation is that I'm adding this box window to existing exterior walls. (can't really follow your new wall steps, Eric)
The 'attic' walls unintentionally continue up to roof above. (just want the box on one level)
Can my process be continued, some how bottom moved up, top moved down?
The walls will go up to a roof.  You need some type of roof to finish off the box.  On the bottom have you tried pony wall settings with say a 12" and a 6" thick wall set to align at outside surface?
...btw, how do you nudge a third window up against two windows (that are either mulled or not)
as you can see from the interior view... it doesn't seem to matter which two, the first two work, the third one won't join.
