Linnukas Posted November 24, 2020 Share Posted November 24, 2020 Hi, I have been looking around for hours to find a straight-forward and easy-enough answer for me to understand, but haven't found it still. Could anyone give me instructions on how to do a boxed out window / bay window manually? I can see, that even people that are quite experienced in construction/Chief Architect struggle with this. I understand that there is no point in using CA's automatic Box-Bay Window tools, if I want to higher the window up past the next floor level (in "open below") and use more separate windows. Here's a rough example of what I'd like to achieve (with less and too low windows). I wanted to link my plan also, but couldn't for some reason... Thanks in advance! Link to comment Share on other sites More sharing options...
GeneDavis Posted November 24, 2020 Share Posted November 24, 2020 Post the plan, please. Close the file. Zip it. Attach the zipped copy. And if your sig (can't see it on my mobile) doesn't show your Chief version and system specs, fix that, too. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 24, 2020 Share Posted November 24, 2020 You just need to make the boxed out area a separate room. You can do this by using a wall with an opening. Then you can set the floor elevation & height of that room. You will also need to change the floor structure and specify no foundation. 1 Link to comment Share on other sites More sharing options...
Linnukas Posted November 25, 2020 Author Share Posted November 25, 2020 Thank you! This is cool. Now, I can't seem to get rid of an excess wall coming from the doorway top. How would you do it? Link to comment Share on other sites More sharing options...
rgardner Posted November 25, 2020 Share Posted November 25, 2020 3 hours ago, Linnukas said: Thank you! This is cool. Now, I can't seem to get rid of an excess wall coming from the doorway top. How would you do it? nohouse.zip Didn't have time to open your file but my guess is that you manually adjusted that wall at some point? Try opening the wall dbx >Structures tab> select default wall top and bottom height radio buttons at top. Link to comment Share on other sites More sharing options...
