RobUSMC Posted November 17, 2014 Share Posted November 17, 2014 Does anyone know how to draw vertical ducts? Horizontal is not an issue using a molding line in plan view. I'm needing a spiral duct to run across the ceiling to a far wall then turn downward towards the floor. Kinda hard to draw a vertical molding line in plan view. Thanks Link to comment Share on other sites More sharing options...
Kiwideziner Posted November 17, 2014 Share Posted November 17, 2014 draw it in elevation. by the way I thought they gave us symbols or something for that in X6. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted November 17, 2014 Share Posted November 17, 2014 Chief now has spiral ducting you can download in the 3D Library. Link to comment Share on other sites More sharing options...
freshrooms Posted June 16, 2015 Share Posted June 16, 2015 I've put some spiral ducts in a plan from the bonus library... having some trouble. Can't select them. Even with the All Off set, in camera view, they are still visible and unselectable. "All off" in the plan view, and they are off. Any ideas? I am using X7. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 16, 2015 Share Posted June 16, 2015 Check your "All Off" layer set. There is likely a layer in that set that is on. They're called "All On" and "All Off", but if you're not careful you can inadvertently turn layers on in the All Off set and off in the All On set. Link to comment Share on other sites More sharing options...
freshrooms Posted June 16, 2015 Share Posted June 16, 2015 I tried that, then turned on each layer... couldn't locate it! Turns out they ended up as the room moldings so I had to delete it from the room specification dialog box. Tricky! Link to comment Share on other sites More sharing options...
