chiefuserjohnG 0 Posted October 30, 2020 How do I stretch the box on layout sheet to fit my page? I used to grab the corner button and just pull it. Share this post Link to post Share on other sites
solver 1564 Posted October 30, 2020 2 minutes ago, chiefuserjohnG said: How do I stretch the box on layout sheet to fit my page? You want to shrink or enlarge the Layout Box proportionally -- height and width at the same time? Hold the C key and drag from a corner handle. Share this post Link to post Share on other sites
Chopsaw 635 Posted October 30, 2020 11 minutes ago, chiefuserjohnG said: I used to grab the corner button and just pull it. Wasn't that great, just like a picture... Try shift select and grab the top tab. 5 minutes ago, solver said: Hold the C key and drag from a corner handle. Do you mean SHIFT + C ? Share this post Link to post Share on other sites
chiefuserjohnG 0 Posted October 30, 2020 thank you both!! Shift+C did the trick. Used to be much simpler though....I used Version 10 for sooo long just upgraded to X12 this summer Share this post Link to post Share on other sites
rgardner 141 Posted October 30, 2020 11 minutes ago, chiefuserjohnG said: thank you both!! Shift+C did the trick. Used to be much simpler though....I used Version 10 for sooo long just upgraded to X12 this summer Layout boxes use c or X when holding down corner to resize picture boxes you can grab the corner and drag. Share this post Link to post Share on other sites
Chopsaw 635 Posted October 30, 2020 12 minutes ago, chiefuserjohnG said: thank you both!! Shift+C did the trick. Used to be much simpler though....I used Version 10 for sooo long just upgraded to X12 this summer I think it was X10 when we lost that functionality. It would be great to get it back even as an alternate. Welcome back to the new forum. You can add your current version and computer spec's to your signature so it is always there when you post. It helps us help you. Share this post Link to post Share on other sites
Alaskan_Son 2454 Posted October 30, 2020 1 hour ago, chiefuserjohnG said: Used to be much simpler though Sometimes with improvements come costs. The behavior changed when they added the ability to reshape layout boxes. By the way, if you want to anchor and resize with a specific corner anchored in position to match the old functionality, I would suggest you familiarize yourself with 2 tools. Place Point Rotate/Resize About Current Point I have these mapped to hotkeys because I use them so much. In this example, Place Point at Corner, toggle Rotate/Resize About Current Point on, select your object and drag the corner while holding the X key. Share this post Link to post Share on other sites
