jonow6 Posted October 20, 2020 Share Posted October 20, 2020 I'm having some trouble with designing up a split level. I've tried looking at some videos and help articles but they don't seem to give me any direction. The project is an existing house with four separate split levels: (1) - Full basement and crawl space below the lower level (2) - Lower level (at grade) (3) - Main level (above the full basement) (4) - Upper level (above the lower level) I am designing the house to be two units, with the basement and lower level being one unit, and the main and upper level being another. See attached sketch. The issue I am having is that Chief doesn't seem to look too kindly on split levels... I need to show the crawl space, lower unit and upper unit on separate levels/layouts. Any ideas on the best way to start laying this out?... Should I do the crawl space on level 0, the lower unit on level 1 and the upper unit on level 2?.. Link to comment Share on other sites More sharing options...
glennw Posted October 20, 2020 Share Posted October 20, 2020 7 minutes ago, jonow6 said: Any ideas on the best way to start laying this out?... Should I do the crawl space on level 0, the lower unit on level 1 and the upper unit on level 2? Yes 1 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted October 20, 2020 Share Posted October 20, 2020 Here are some videos from Chief. You'll be a split-level pro after watching these.... https://www.chiefarchitect.com/videos/watch/9917/focus-creating-a-split-level-home.html https://www.chiefarchitect.com/videos/watch/322/creating-a-split-level-structure.html https://www.chiefarchitect.com/videos/watch/323/creating-a-split-entry.html https://www.chiefarchitect.com/videos/watch/6066/floorplan-garage-breckenridge-home-design.html https://www.chiefarchitect.com/videos/watch/6129/generating-a-roof-on-multiple-levels-of-a-structure.html Here are some from Chief users who you should watch all their Youtube videos... 1 Link to comment Share on other sites More sharing options...
lbuttery Posted October 21, 2020 Share Posted October 21, 2020 I generally use the 4' rule if the next level is > 4' then it probably should be another floor Lew Link to comment Share on other sites More sharing options...
