Lighthouse 4 Posted October 16, 2020 I created a winder stair but can't put a door in the wall below it. Please see screenshot and attached plan. Thanks! (plan is now attached) stair question.plan Share this post Link to post Share on other sites
solver 1581 Posted October 16, 2020 You are using X10? Share this post Link to post Share on other sites
DzinEye 266 Posted October 16, 2020 36 minutes ago, Lighthouse said: and attached plan You didn't attach the plan Share this post Link to post Share on other sites
Lighthouse 4 Posted October 16, 2020 32 minutes ago, solver said: ???? It won’t let me attach it, I backed it up to a zip file and tried to attach the zip, it’s It’s under the size limit but just wont attach for some reason Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 51 minutes ago, solver said: ???? I deleted all all the CAD details and was able to upload the plan Share this post Link to post Share on other sites
solver 1581 Posted October 17, 2020 I changed the top two winders to landings. Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 thanks. So is it a bug that you can't do it with a stair? I tried the winder method, but couldn't get the upper stair to recognize the winder and start at that height . How did you create the winders? As PS? And could you attach the plan so I can see the settings? thanks again! Share this post Link to post Share on other sites
solver 1581 Posted October 17, 2020 1 minute ago, Lighthouse said: How did you create the winders? 51 minutes ago, solver said: I changed the top two winders to landings. Share this post Link to post Share on other sites
solver 1581 Posted October 17, 2020 2 minutes ago, Lighthouse said: And could you attach the plan so I can see the settings? Done in X12 Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 got it. But I'm curious how you connect the upper stair section to the upper landing. Do you just pull a straight stair section off the landing, or is there some other step that I should be doing (because that doesn't work, puts the stair on the floor, even though the landing is at the correct height and I have "figure stair from landing" checked Share this post Link to post Share on other sites
glennw 992 Posted October 17, 2020 Make the wall a No Room Definition wall - works in X12. Post back if it doesn't work in X10. Share this post Link to post Share on other sites
solver 1581 Posted October 17, 2020 Watch on YouTube: http://youtu.be/Ttne9gF859U?hd=1 1 Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 Eric, thanks so much for creating that video! btw, what software do you use to do that screen recording? Super helpful, although it turns out that those options are not avail in X10. Seems like there are lots of improvements in 12. I have resisted upgrading b/c I own 2 X10 licenses, so it's a big investment. Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 12 hours ago, glennw said: Make the wall a No Room Definition wall - works in X12. Post back if it doesn't work in X10. Glenn, that worked! How did you think of that? It just didn't occur to me that it was screwing up the winder by making a room. Why is everyone smarter than me :-) Share this post Link to post Share on other sites
Dermot 576 Posted October 17, 2020 Just a couple of comments but with the caveat that I did not actually look at your plan. There have been a number of stair improvements since X10 but the one that Eric is highlighting is that multiple landings can be connected to create stairways now and the program will automatically calculate the heights for you. In X10, you could still use multiple landings but you would have to figure out and set the heights manually as well as turn off the railings where you don't want them. Since automatic winders have always been somewhat touchy, the ability to create your own with landings gives you some more options with much better control. As to why the door doesn't work with winders and why Glenn's solution works, I got nothing at the moment. I will say this though, this is why we really like having Glenn around, especially during beta testing. Share this post Link to post Share on other sites
Lighthouse 4 Posted October 17, 2020 Here's the design so far without a railing. Thanks everyone for your help! Share this post Link to post Share on other sites
solver 1581 Posted October 17, 2020 2 hours ago, Lighthouse said: what software do you use to do that screen recording? https://screencast-o-matic.com Share this post Link to post Share on other sites
