mtldesigns 44 Posted October 15, 2020 I am trying to combine a Electric legend with a schedule. So this thing has to show the CAD symbol, type of elec. fixture, quantity and comment field. I have spent almost an hour searching, and maybe I overlooked it.. but how can I get the row heights smaller on a schedule? I know how to reduce the scale of the 2D image and how to manage the text size and column widths.. but cannot for the life of me find how to adjust the height of the rows. Share this post Link to post Share on other sites
Chopsaw 635 Posted October 15, 2020 Manage the column width of your Symbol column which may require you to shorten the column heading also. Share this post Link to post Share on other sites
mtldesigns 44 Posted October 15, 2020 That's what I have checked Eric.. Chop, I pull the column grips horizontally and the height stays the same... Share this post Link to post Share on other sites
solver 1569 Posted October 15, 2020 Always best to attach the plan file. Share this post Link to post Share on other sites
Chopsaw 635 Posted October 15, 2020 7 hours ago, mtldesigns said: Chop, I pull the column grips horizontally and the height stays the same... Something odd is going on then. I can't reproduce your situation. It could be a font issue or something I have not run across or can't remember. Custom cad blocks or non standard scaling ? Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted October 15, 2020 8 hours ago, mtldesigns said: That's what I have checked Eric.. Chop, I pull the column grips horizontally and the height stays the same... Looks to me like you’re not showing us the most relevant item on the schedule. That row height is controlled by the widest image in the schedule. Either change the 2D Block being used for that object, exclude the object from the schedule, or change your scaling settings in the schedule. Without seeing the plan this is obviously a guess but I bet you have either a big chandelier or a long fluorescent type fixture in the plan. Share this post Link to post Share on other sites
mtldesigns 44 Posted October 15, 2020 Gone all day and back at it.. That was it Michael. I deleted the three ceiling fans, "just to see".. because that was the only fixture that could be big enough to mess with the scaling. I still wish that I more control over the width and height of these schedules.. like a excel spreadsheet. Thanks gents! Share this post Link to post Share on other sites
Chopsaw 635 Posted October 15, 2020 57 minutes ago, mtldesigns said: I deleted the three ceiling fans, "just to see".. because that was the only fixture that could be big enough to mess with the scaling. So then you likely don't want to use the scaling options at all in that situation. Share this post Link to post Share on other sites
