Upward1 Posted September 4, 2020 Share Posted September 4, 2020 please tell me how to calculate the length of all the walls Link to comment Share on other sites More sharing options...
Chopsaw Posted September 4, 2020 Share Posted September 4, 2020 A wall schedule will tell you the length of all the individual walls but I am not sure that it will total them for you. It may need a custom macro. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2020 Share Posted September 4, 2020 2 minutes ago, Chopsaw said: A wall schedule will tell you the length of all the individual walls but I am not sure that it will total them for you. It may need a custom macro. You can just copy/paste the schedule into an excel spreadsheet and add them up in there. No macros necessary. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 4, 2020 Share Posted September 4, 2020 3 minutes ago, Alaskan_Son said: You can just copy/paste the schedule into an excel spreadsheet and add them up in there. No macros necessary. Thanks Michael, That should work for most situations, but I think it could be set up to be live although it would be a lot of work to do it. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2020 Share Posted September 4, 2020 18 minutes ago, Chopsaw said: Thanks Michael, That should work for most situations, but I think it could be set up to be live although it would be a lot of work to do it. Yes. Using some custom macros it can be done so that there’s a live total in the schedule. I’ve set up a handful of similar systems for other users. It really kinda depends on what the end goal is as to whether it’s worth the trouble of setting up and maintaining said system. Link to comment Share on other sites More sharing options...
Upward1 Posted September 4, 2020 Author Share Posted September 4, 2020 maybe there is another way to read the green plate under the walls? Link to comment Share on other sites More sharing options...
glennw Posted September 4, 2020 Share Posted September 4, 2020 The Material List will give you individual wall lengths and a total length for each wall type. 1 Link to comment Share on other sites More sharing options...
Alchemyjim Posted December 1, 2024 Share Posted December 1, 2024 You can use the wall schedule to display the wall length totals. Add "Wall Length" to the column in the dbx. Make sure to select "Sum Similar Rows". 1 Link to comment Share on other sites More sharing options...
