carowe
Dormers AND Shed Roof help
Posted (edited)
I am attempting to recreate the attached room for a client so that we can do some interior work.  The room is over a garage and has two dormers in the front, which have the same ceiling height as the rest of the room.  The back wall is a shed roof.  I can follow the directions and get the dormers in this room, but the ceiling slopes and in the spaces to the far sides of the dormers are not open as in the picture.  I can get a shed dormer on this room but then I can't figure out how to get the dormers in place.  I have tried doing the dormers first and then doing the shed roof, and vice versa and cannot figure this out.  Seems as though the roofs are kicking my butt on my last two projects, but I know that's how you learn.  Help would really be appreciated.
Edited by carowe
typo
It might help to post the plan so others can see what you have done so far.
Steve Nestor has posted some really good videos, you might try this one:
It would also help to show images of your problems.
Here are some images and the plan.  I feel like I'm missing something really simple.  I can get the dormers in, correct size and placement, with the opening in the walls next to them.  However, I have walls that are uncovered, and the back wall is angled and should be flat to the exterior wall as in the pictures in my first post.  Thanks!
Both Walls.pdf
Dormers.pdf
Tridente.plan
Please post images directly -- no need to make a PDF of an image. This makes it easier for others as an image shows in the forum.
27 minutes ago, carowe said:
Try opening this view and selecting that wall that is a half knee wall between your dormers open it and make it invisible (or use the make invisible wall button once you have it selected.). For the other side a picture of the outside of the house may help explain what you need to do for the roof.
Thanks for the help!!!  I've got the dormers now!  So halfway there - but how do I make the ceiling flat, rather than sloping, to the back wall and have the wall opposite the dormers vertical with windows in it like the attached picture of the existing back wall?
EXISTING BACK WALL.pdf
back wall.pdf
I locked the ridge height on the back roof plane and changed it to a 3 pitch, not sure if the pitch or your ceiling height is correct but this is the result.
Your back roof plane was sitting on the first floor and cutting the second floor wall off. I also unchecked the invisible button.
    28444
    Lufunoraf
    Lufunoraf
