carpenterjon Posted July 26, 2020 Share Posted July 26, 2020 Chief Architect Premier 12 I did my drawings and I'm happy with where they are. However, when I send them to Layout and PDF they do not fill the whole 24x36 Arch D page. What did I do wrong? Thank you. 1 1 Link to comment Share on other sites More sharing options...
Kiwideziner Posted July 26, 2020 Share Posted July 26, 2020 scale to layout 1 Link to comment Share on other sites More sharing options...
carpenterjon Posted July 26, 2020 Author Share Posted July 26, 2020 20 minutes ago, Kiwideziner said: scale to layout That's not helpful. 1 2 Link to comment Share on other sites More sharing options...
carpenterjon Posted July 26, 2020 Author Share Posted July 26, 2020 20 minutes ago, solver said: That's something you need to manage. Search the Chief website for articles and videos on Layout. That's really not helpful. 1 1 Link to comment Share on other sites More sharing options...
rgardner Posted July 26, 2020 Share Posted July 26, 2020 38 minutes ago, carpenterjon said: That's really not helpful. They are trying to help you know what to search. Here is the link for where to find the videos. https://www.chiefarchitect.com/videos/watch/48/creating-layouts-and-construction-documents.html?playlist=105 Since there are many variables on what the issue is and the description you are giving doesn’t help to narrow it down the best bet is to search the database for the answer with your information or post the layout file here if you want help from the pros. Sorry not trying to be rude at all but Chief is a very complex program that has so many uses that they could ask questions for hours back and forth before figuring out what the cause of the problem is and how to remedy it. Best practice is a concise but descriptive question and explanation of the situation, pictures with description of issue, or best yet is to upload the plan or layout file. Hope this helps. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 26, 2020 Share Posted July 26, 2020 2 hours ago, carpenterjon said: That's not helpful. You really haven't helped yourself with your description, most of us don't want to play 20 questions..... and you haven't posted the Layout for Comment or even any pictures of the Issue, ie: you need to help us help you in other words... However is sounds like you didn't send it to Layout at the right Scale ( 1/4" = 1 ft being typical ) , you can rescale the Layout views if so ..or send them again at the correct Scale. Make sure your Drawing Sheet Setup is correct and set to the right page size and scale and go from there.... for both Plan and Layout.... https://www.chiefarchitect.com/support/article/KB-00725/defining-the-drawing-sheet-setup-for-printing.html M. 1 1 Link to comment Share on other sites More sharing options...
