Steve_Nyhof Posted July 13, 2020 Share Posted July 13, 2020 I pulled the daylight walls down without an issue. I broke the wall where I wanted and in 3D pulled the wall down. good Then I pulled the frost wall down on the side (walkout area) and that worked fine. good But when I pull the top down (1) to the top of my conc floor (walkout), it also pulls down, (2) and (3). Is there a way to lock a part of the wall so it is unaffected? Thank you Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 So I found I needed to make a pony wall if I was going to put windows and doors in the wall on the Lower level. Then breaking things and dragging down worked great. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 So along these same lines, I have this all figured out, my heights are perfect for walkout and daylight. However, on my elevation view, there is a line where the First floor siding is overlapping the lower wall siding. Do I have some height issue? The 3D looks perfectly Link to comment Share on other sites More sharing options...
SNestor Posted July 13, 2020 Share Posted July 13, 2020 @stevenyhof - without the plan it’s hard to say. You might open the wall DBX and make sure walls top is default. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 Ok, so I see that the siding does overlap the floor joist and sill plate by 1.5" - so that seems to be the interference. Thoughts? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 2 minutes ago, SNestor said: @stevenyhof - without the plan it’s hard to say. You might open the wall DBX and make sure walls top is default. I will look at it. I am setting up Chief so working on getting all my walls and heights set as defaults so it is not much of a plan. So you are saying that it should not be overhanging that that? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 Yes it is Link to comment Share on other sites More sharing options...
SNestor Posted July 13, 2020 Share Posted July 13, 2020 Just now, stevenyhof said: Yes it is Yea...so my suggestion is not the problem. Might check to make sure the wall is aligned correctly with the wall above. Sometimes the main layers get screwed up when you use pony walls. Click on the wall in plan view...and look for this symbol.... Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 I'm thinking it may be a foundation thing. Typically when siding is applied, it is put on an inch or so over the foundation wall. When I check the floors between the top of the first and the bottom of the second, they line up, and there is no visible line on the hatch pattern. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 Just now, SNestor said: Yea...so my suggestion is not the problem. Might check to make sure the wall is aligned correctly with the wall above. Sometimes the main layers get screwed up when you use pony walls. Click on the wall in plan view...and look for this symbol.... Very good - I will check that Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 It did show up for this view, and now that it is lined up, the icon is no longer there - so it must be lined up. Maybe I just need to start again as I mess with things that could be causing this. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 13, 2020 Author Share Posted July 13, 2020 I set the main floor to Default to bottom and it seems to work - So maybe when it is over daylight and walkout wall with the same material as the first floor, you need to default to bottom so it is not overlapping like it does on a foundation wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 13, 2020 Share Posted July 13, 2020 5 minutes ago, stevenyhof said: the icon is no longer there - so it much be lined up. Not necessarily ( but probably in this case ) alignment could be wrong if wall is reversed or if the Wall is more that 1/2 its own width off the one above or below , then chief thinks it's deliberate and you won't get the icon. The Reference Layer may show it in that case? or put a BC CS Camera through the wall , by defaul Chief builds the Siding (stucco etc) down to the bottom of the Floor Structure ...and no further ie the 1-1.5" hang down in the Real world. * also check the upper wall bottom height height is at default if you were pulling in 3D? M. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 13, 2020 Share Posted July 13, 2020 1 minute ago, stevenyhof said: It did show up for this view, and now that it is lined up, the icon is no longer there - so it much be lined up. Maybe I just need to start again as I mess with things that could be causing this. Two schools of thought on manually editing wall heights, I'll put one oversized check mark under the "don't manually adjust your walls" column. It causes more problems than it solves in my experience, especially when you're working through design iterations. Also, you might consider making your walkout a floor 1 and leave your stem walls on floor 0. A lot more control that way IMO 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 13, 2020 Share Posted July 13, 2020 @stevenyhof best practices for posting here is to post a .plan file, we're far more effective as a group when we have access to the .plan 1 Link to comment Share on other sites More sharing options...
