Spanish/Mediterranean style stair
OneChickNoHammer
Hello everyone,
I'm working on a mediterranean style design and I would like a staircase similar to the posted picture where the drywall/plaster comes to the bottom of each tread.  I'm able to do this using the custom stringer option, for the most part, but have a not so lovely line following the bottom of the stringer.  Any suggestions on how to resolve this or am I stuck doing the polyline solid thing?
Thank you,
Lisa
Well... I know one way, that is to make the stringer 'height below tread' really deep... like 8 or 9 feet until it disappears into the floor.
But if you don't use vector view you wont see the line if you match materials and uncheck 'open underneath'
One relatively simple way...use 2 stairs.
  • replicate the stair
  • make the copy 2" wide (that's as narrow as chief will allow.
  • place this narrow stair flush with the drywall
  • paint the stringer with the drywall material
  • remove the railing from the original, main stair.
  • reduce the original stair by 2" (butting it up to the 'railing stair'
robdyck,
Thank you for your response.  That is a neat way of doing it and won't cause problems for other stairs below this one, say for the wine cellar. :)  I hope Chief will make it a little easier though in an update by allowing us to change the material on that particular surface.
Lisa
