RonChief Posted June 16, 2020 Share Posted June 16, 2020 Hello guys. I have a problem here. I want to copy the properties and layer of one object and paste it to the other object. Is there a way like match properties in Autocad here in Chief Architect? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 16, 2020 Share Posted June 16, 2020 Not sure if it works the same as Autocad but yes there is a Match Properties tool and then once you have activated it the Apply Properties tool will show up on the active toolbar. Switching layers is a separate function done in the objects DBX (dialogue box) 1 Link to comment Share on other sites More sharing options...
RonChief Posted June 16, 2020 Author Share Posted June 16, 2020 Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 16, 2020 Share Posted June 16, 2020 We also have the Object Eyedropper and the Fill Style Eyedropper. The latter won’t do exactly what you are asking for but based on your question I think it’s some thing you should be aware of anyway. 1 Link to comment Share on other sites More sharing options...
glennw Posted June 17, 2020 Share Posted June 17, 2020 There is a tool specifically designed for that. The Layer Eyedropper enables you to select an object and apply its layer to another object. 1 Link to comment Share on other sites More sharing options...
RonChief Posted June 17, 2020 Author Share Posted June 17, 2020 @glennw @Alaskan_Son Thank you very much sirs! 1 Link to comment Share on other sites More sharing options...
