robdyck Posted June 2, 2020 Share Posted June 2, 2020 Has anyone else experienced a back-splash being cut (by it thickness amount) at a window(s) because of the back-splash also being at the side of the cabinet? I typically use an 18-20" high backsplash and it always on the sides. If I remove the backsplash from the side, the gap disappears. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 2, 2020 Share Posted June 2, 2020 Only seems to be an issue if you don't have a proper filler between the cabinet and a wall. Link to comment Share on other sites More sharing options...
robdyck Posted June 2, 2020 Author Share Posted June 2, 2020 48 minutes ago, TheKitchenAbode said: Only seems to be an issue if you don't have a proper filler between the cabinet and a wall. I had my cabinet 1" away from the wall. If I use a filler, that allows me to have a side backsplash controlled by the filler, and to turn off the side backsplash on the cabinet. Seems like a bug to me as I've not noticed this in past versions. I will report it to Support. Link to comment Share on other sites More sharing options...
DzinEye Posted June 2, 2020 Share Posted June 2, 2020 I gave up using cabinet dbx backsplash ages ago. Sometimes it works great, but usually there's something to make it easier to just draw a custom backsplash. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 2, 2020 Share Posted June 2, 2020 7 minutes ago, robdyck said: I had my cabinet 1" away from the wall. If I use a filler, that allows me to have a side backsplash controlled by the filler, and to turn off the side backsplash on the cabinet. Seems like a bug to me as I've not noticed this in past versions. I will report it to Support. I agree it looks like a bug. Have never encountered it before though as I always use separate wall fillers and custom backsplash or wall material regions. 2 Link to comment Share on other sites More sharing options...
