DarkPony Posted May 15, 2020 Share Posted May 15, 2020 Newbie to Chief Architect. While designing a walkout basement plan, in the foundation layout, I created a stem wall with brick pocket on framed exterior basement wall. This stem wall is 37" below grade. All looks well until I add the framed wall on top of it.After adding framed wall, going to the floor perspective...poof, pony wall gone. Racking my brain to figure out why? In advance, thank you for any help....X12 software. Link to comment Share on other sites More sharing options...
DarkPony Posted May 15, 2020 Author Share Posted May 15, 2020 Thank you, I will view content. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 15, 2020 Share Posted May 15, 2020 The KnowledgeBase ( KB ) is very handy for the Basics and then some , since in many cases you won't have been the 1st to ask..... https://www.chiefarchitect.com/support/article/KB-00064/drawing-a-pony-wall.html and don't forget the Video library either........... https://www.chiefarchitect.com/videos/watch/5455/creating-pony-walls-for-above-grade-brick.html?playlist=85 M Link to comment Share on other sites More sharing options...
robdyck Posted May 15, 2020 Share Posted May 15, 2020 7 hours ago, DarkPony said: All looks well until I add the framed wall on top of it. More info is needed here. Did you 'draw' a framed wall over the pony wall? 2 walls cannot occupy the same space in plan view. Or did you 'add' the framed wall using the pony wall tools? If so, did you set the wall elevation correctly? Post pictures, post the plan. Typing descriptions is sooo 2018. Link to comment Share on other sites More sharing options...
SNestor Posted May 15, 2020 Share Posted May 15, 2020 Just post your plan and one of the many experts here on the forum will help you. 1 Link to comment Share on other sites More sharing options...
