bmcpherson Posted May 7, 2020 Share Posted May 7, 2020 How do you make the shelf create a corner? Is this an option? It wastes so much time to have to draw it myself and create an actual object. I really need some help, because I have to do this often! Thank you! using x10 Link to comment Share on other sites More sharing options...
Rpadge Posted May 7, 2020 Share Posted May 7, 2020 Have you searched the Chief website? I see this, maybe it will help https://www.chiefarchitect.com/videos/watch/1537/corner-cabinets.html Link to comment Share on other sites More sharing options...
bmcpherson Posted May 7, 2020 Author Share Posted May 7, 2020 I am NOT talking about a corner CABINET. I am talking about a SHELF. And yes, I did that first and it wasn't helpful. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 7, 2020 Share Posted May 7, 2020 What do you mean by "...create a corner"? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 7, 2020 Share Posted May 7, 2020 But your subject title and your question leads off by "suggesting," at least to me, that you would want the shelf to create a corner shelf. I'm confused...happens a lot. 5 hours ago, bmcpherson said: How do you make the shelf create a corner? Link to comment Share on other sites More sharing options...
robdyck Posted May 7, 2020 Share Posted May 7, 2020 The shelf tool creates a rectangle only. If you want a clipped corner, or a shelf that runs into , say a 45 degree corner, then you have already alluded to the unfortunate fact that it will need to be created manually. If you need to do it often, as you say, then place examples of your manually created shelves in the library for quick access and easy editing. Just use a counter top, adjust its properties to match that of a shelf, group select it, block it, add it to library. Then all you need to do in the future is place it, unblock it, and adjust its shape. Link to comment Share on other sites More sharing options...
