Pole barn garage plan design request.
PurdueFan
Amateur user of HDP. Allows me to build for ideas but not for real build plans.
Looking for someone to take my HDP idea and create plans.
- Detached pole barn style garage, 30' x 40', unfinished inside, concrete pad, 2 garage bays.
- Located in Ohio.
- Can share details on local code needs, specifics on build.
- Exterior: Siding, 3' of lick-and-stick stone on front. Shingle roof.
ASAP need date. Use CAD / CAM for machining and printing, kudos to those of you who are good at home designing. IMO, it's harder to get things right on home designing than it is for 4-axis machine CAD.
Thanks in advance!
Not interested but I would advise against using stone on just the front - it tends to look fake and IMHO is the mark of an amateurish designer. Better to use all that same amount of stone and do a stone skirt with siding above. The problem is, people see buildings from more than one viewpoint - and as soon as you move around the corner you see that it's just fake thin veneer and it loses the effect.
Stop stone or change stone heights at inside corners only.
I see more folks changing the exterior materials wall by wall. Also, you avoid pouring a stone/brick lug where you have a full wall of siding and when you do pour it you are getting the cost spread over ±twice the stone/brick surface area.
Have faith you can do it :)
don't these get you mostly there ?  ( I am not really sure what features Pro is missing these Days vs Premier)
https://www.homedesignersoftware.com/support/article/KB-01081/creating-a-pole-barn-structure.html
https://www.chiefarchitect.com/support/article/KB-00598/creating-a-post-and-beam-structure.html
https://www.chiefarchitect.com/support/article/KB-01069/designing-a-traditional-pole-barn-structure.html
oh and watch out for that ankle breaker front step in the photo...
Thanks for the support comment! No plumbing, interior finishing, basically a nice-looking large shed IMO. That said, still give props to those of you who do home design. I do CAD / CAM for a machine and while some code is complex, machines don't have opinions / feelings. You're designing for an emotional topic / largest investment a person, or couple, makes in their life. Add local codes on top of it, there's a lot of people to make happy.
Already using the first link and at the post / footing stage. Attached file is a CA sample download plan, can't edit it in HDP 2019. Would be nice to see settings for various items, make adjustments and see results, apply learned info to my design. Anyone know if there's a sample pole plan that work with HPD 2019?
Pole Building.plan
Pole Building.plan
I think that plan is from the Original Tutorial in link no# 3 ( re-written this year) and may include features used that Pro does not have or isn't capable of , but you can download the tutorial PDF and check out most of the Settings and see if HD Pro is indeed capable.
    30075
    peterpan
    peterpan
  • Similar Content
    • By jkonecny
      Hello,
      I'm needing some help. Just getting started with CA X10 and with a new Surfacebook 2 machine. I have the GTX 1060 GPU version 398.36 (most up to date version).
      The problem i'm having is that if I open up a 3d view, then close the 3d view after no longer needing it, my 2d plan view seems to do some weird freeze thing where I can no longer see my mouse or anything. Of course I know that the program isn't freezing because I can still utilize the file/save screen and can still exit the software. If I open another 3d view prior to exiting, I can switch back to the plan view with no problem and everything works as it should. However, the moment I close a camera or 3d view, my 2d plan goes straight to crap and I end up having to save and completely re-open the program.
      I've read some of the other topics that include issues like this in the past (a year or so ago) but i'm wondering if there is something i'm missing that I need to do? other than installing an old out of date Nvidia Driver.
    • By deanbrenneman
      FREELANCE HELP WANTED - Immediate and ongoing basis
      Need someone to convert 2D Auto Cad files to Chief, and then make 3D Chief files for my use in designing renovations and additions.  Looking for someone to do this on an ongoing basis, as I have a constant need for this and don't have enough time to do it all myself.   Location is not an issue, as this would be remote work.  Some projects will just need basic shell with standard finishes, some may be fairly elaborate.  Please respond to dean@DeanBrennemanArchitect.com
    • By NicholasK
      Can anyone, ideally reasonably local to Napa valley, help with the following?
      Thanks
      Nick
      Summary:
      CUP and DR approvals in place for expansion to Calistoga lodging, see this link for details: http://www.ci.calistoga.ca.us/Home/Components/Calendar/Event/3002/272?npage=3&toggle=allpast
      Initial CAD design for above converted to 3D model in Chief Architect X9, File is available.
      Original Drafter has dropped out.
      Now need drafting help in the next couple of weeks to (Details in attached pdf):
      I. Validate the changes I have made to the base model.
      II. Incorporate design decisions which need to be made into the model.
      III. Incorporate design decisions we have made into the model.
      And:
      IV. This is the short term scope to enable us to have close to final floor plans ready to take to structural engineering. If
      available and interested additional Drafting scope is to provide normal drafting services support from completed
      3D model and floor plans through building permit issue.
      Nick Kite
    • By Walker
      I am a long time user of Chief Architect since version 3.0 and have been in the residential design business for over 30 years designing projects of all sizes in renovations, additions and new homes. I can provides services to you quickly and for a reasonable fee and have worked with individuals throughout the U.S successfully.  The link below will take you to my website where you can see some of my finished homes. While I am located in the Southeast, I have worked with homeowners as well as other designers, builders and developer/builders from Texas to Maine in developing their plans, doing revisions, and complete construction documents. If you have any questions or would like to discuss your project and needs please contact me.
    • By Designers_Ink
      With over 20 years of experience, I have designed homes all over the United States.  My design philosophy is to get to know my client's by listening to their needs very carefully.  I can then produce a design that fits both their functional needs, as well as their style.  I also work with other design professionals when they need assistance meeting a deadline or just have too much work and not enough time.  Please take the time to view my website at www.designersink.us to view samples of my recent work.  I can also send you examples of recently completed construction document plans sets upon request.  It is always my goal to EXCEED my client's expectations.  I look forward to an opportunity to exceed yours!
