Anyone know why inconsistent wall fill between windows / doors?
DzinEye
My best guess is because the spacing is not the same.  Take a look at the attached picture.  When you click on the dimension, the program will show the actual distance between the windows.  If the distances are not the same, you will not get the same results.
16 minutes ago, Dermot said:
Because the spacing is not the same.  Take a look at the attached picture.  When you click on the dimension, the program will show the actual distance between the windows.
That's what I did to make sure they were the same before I posted
28 minutes ago, Renerabbitt said:
Is it the same :huh:?
Delete the left window and try a Copy/Paste+Reflect About Object on the right window.
Tried that both ways... delete left vs. right and no change either way.
I tried copying that wall and those windows into a new plan to post it here and then of course the problem goes away
It's the invisible attic wall that connects in the middle of one of the windows.  It's preventing the windows from mulling together.
In the future, you should always report these kinds of issues directly to technical support.
Didn't know it was a tech support type issue.
Okay... I deleted those invisible attic walls but the problem still persists.
Did you try it?
Strike that... now I see it's automatically come back as a regular attic wall on a layer that I had turned off.
Edited by DzinEye
    30101
    pbb17t
    pbb17t
