DzinEye Posted March 31, 2020 Share Posted March 31, 2020 When walls get within a set distance (Chief bases this distance on wall thickness) from one another, they want to snap together, which is usually great, but not always. Is there a way to prevent it? Would like to know the answer in general, but especially asking for a condition where a rail comes up perpendicular to the wall, but I don't want the joint between the two parallel/co-linear walls snapping to the intersection with the perpendicular rail. Link to comment Share on other sites More sharing options...
rlackore Posted March 31, 2020 Share Posted March 31, 2020 You can use a room divider, perpendicular to the railing. This will prevent the railing and the other wall from joining. Example (dividers in pink): 1 Link to comment Share on other sites More sharing options...
DzinEye Posted March 31, 2020 Author Share Posted March 31, 2020 Perfect, thanks guys. I guess no magic switch to turn off wall snapping on a case by case basis though. Link to comment Share on other sites More sharing options...
Dermot Posted March 31, 2020 Share Posted March 31, 2020 There is no easy way to prevent walls from snapping together. Just some interesting workarounds. If all you want to do is have your railing post offset from the main wall, there are controls to do this in X12. You can also switch between having a full post, half post, or none. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted March 31, 2020 Author Share Posted March 31, 2020 14 minutes ago, Dermot said: If all you want to do is have your railing post offset from the main wall, there are controls to do this in X12. You can also switch between having a full post, half post, or none. 6 minutes ago, solver said: Easy to offset the post, no way to offset the top rail. Thanks Dermot, Yes, I've used that feature a few times now (whether a post or 1/2 post shows at the wall)... but does that prevent the wall from seeing the railing as intersecting? Eric's response makes me think not, but perhaps I'm wrong. I'm working in a project I have to keep in X11 for this particular example. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 31, 2020 Share Posted March 31, 2020 Specifying "Rail to Post" in the Rail Style panel works for 3D. Plan view shows one line connected to wall. Link to comment Share on other sites More sharing options...
