stager386 Posted March 16, 2020 Share Posted March 16, 2020 When I do a screen capture of a rug that is 8x10, it's an easy way to add it to my library. Now I want to capture a rug that is round. How do I do that, since the capture tool is all straight lines? Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 16, 2020 Share Posted March 16, 2020 2 minutes ago, stager386 said: When I do a screen capture of a rug that is 8x10, it's an easy way to add it to my library. Now I want to capture a rug that is round. How do I do that, since the capture tool is all straight lines? You would need to make it a png and delete the white background in an external editor. It would not be tileable. Can you paste it here? Link to comment Share on other sites More sharing options...
stager386 Posted March 16, 2020 Author Share Posted March 16, 2020 It's 8' round. I have 7 round rugs close to the same size in different colors and patterns, so if you tell me how you do this, that would be great! Thank you! Link to comment Share on other sites More sharing options...
VHampton Posted March 16, 2020 Share Posted March 16, 2020 A quick way to do this is with the Poly-line solid method. It won't be perfect since each texture gets layered over the next... and you may see an 1/8th inch thick build-up. But it's good enough to fake in a 3d camera view. Attached is a 3ds symbol which should get you going! BTW... this was done really quickly. In case you want something to match more closely, I can resend. Best, Val Round Rug .3ds Link to comment Share on other sites More sharing options...
stager386 Posted March 16, 2020 Author Share Posted March 16, 2020 Thank you! Link to comment Share on other sites More sharing options...
VHampton Posted March 16, 2020 Share Posted March 16, 2020 My pleasure. Here's the plan so you can see how it works. Hopefully you're using X-12. Carpet plan .plan Link to comment Share on other sites More sharing options...
ACADuser Posted March 16, 2020 Share Posted March 16, 2020 For circle png see this Link to comment Share on other sites More sharing options...
stager386 Posted March 16, 2020 Author Share Posted March 16, 2020 3 minutes ago, VHampton said: My pleasure. Here's the plan so you can see how it works. Hopefully you're using X-12. Carpet plan .plan I am using X-11 Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 16, 2020 Share Posted March 16, 2020 4 minutes ago, VHampton said: My pleasure. Here's the plan so you can see how it works. Hopefully you're using X-12. Carpet plan .plan VHampton, you can always use the polyline subtraction tool in your active toolbar so you aren't stacking. No lip that way...just an FYI Link to comment Share on other sites More sharing options...
VHampton Posted March 16, 2020 Share Posted March 16, 2020 That's correct... and part of why it only took about a minute to "stack" everything. Anyway ...Just opened X-11. Takes 2 minutes to re-do, and using your suggestion. The right way. ...BTW very impressive renders on your site. Are all of them done using Chief? or is there a hint of Lumion as part of the rendering process? Link to comment Share on other sites More sharing options...
VHampton Posted March 16, 2020 Share Posted March 16, 2020 X-11... This was again made using poly line solids... But with a cut-out for each piece, so that the rug reads as one. The 8 foot section was created first. Then it gets a poly line solid "hole" for the middle section. The middle section gets slid into position... and likewise, it gets a cut-out for the center. The center section goes into place... and voila. (3) pieces all at the same height. No shadows lines. Round carpet.plan Round Carpet .3ds Link to comment Share on other sites More sharing options...
stager386 Posted March 16, 2020 Author Share Posted March 16, 2020 2 minutes ago, VHampton said: X-11... This was again made using poly line solids... But with a cut-out for each piece, so that the rug reads as one. The 8 foot section was created first. Then it gets a poly line solid "hole" for the middle section. The middles section gets slid into position... and likewise it gets a cut-out for the center. The center section goes into place... and voila. (3) pieces all at the same height. No shadows lines. Round carpet.plan Round Carpet .3ds Gosh, thank you so much! Link to comment Share on other sites More sharing options...
VHampton Posted March 16, 2020 Share Posted March 16, 2020 My pleasure. Link to comment Share on other sites More sharing options...
