amaliya Posted February 19, 2020 Share Posted February 19, 2020 Hi, I am trying to create a multiple level terrain, but it is not working. Please, help if you know what to do and please tell me what I am doing wrong. What am I missing here?1856 Glenmorrie Ter Plans (1).pdf I attached the elevation plan, and you can see that the terrain is 45degrees higher, which is where I am having trouble getting it right. I would really appreciate if someone can help me out. Thanks in advance! Amal Deck.plan Link to comment Share on other sites More sharing options...
Mark3D Posted February 20, 2020 Share Posted February 20, 2020 You need to keep elevation data simple never put elevation data on top of other elevation and its a good idea to change the elevation data layer color to blue or other that stands out in floor plan view open the attached plan see if it give you some clues Deck.plan Link to comment Share on other sites More sharing options...
amaliya Posted February 20, 2020 Author Share Posted February 20, 2020 Thanks! But I can't open a 3D view camera now. why isn't it letting me open the 3D window? Link to comment Share on other sites More sharing options...
amaliya Posted February 20, 2020 Author Share Posted February 20, 2020 never mind I figured it out, thanks so much! Link to comment Share on other sites More sharing options...
amaliya Posted February 20, 2020 Author Share Posted February 20, 2020 Now the client sent me finally the right dimensions. If you can see the path is really different, I mean different angle etc. How do I change it? Thomas Deck—More measurements (1).pdf Link to comment Share on other sites More sharing options...
Mark3D Posted February 20, 2020 Share Posted February 20, 2020 I can have a go at it but can you get some site photos that would help Link to comment Share on other sites More sharing options...
Mark3D Posted February 20, 2020 Share Posted February 20, 2020 I did not read your post right I thought you were asking for it to be done, just raise the top elevation region might get you moving in the right direction Link to comment Share on other sites More sharing options...
amaliya Posted February 21, 2020 Author Share Posted February 21, 2020 I don't even understand the way they wrote measurements Link to comment Share on other sites More sharing options...
Mark3D Posted February 21, 2020 Share Posted February 21, 2020 Have a look at this file it may be a bit wrong but it should give you a place to start from Deck.plan Link to comment Share on other sites More sharing options...
amaliya Posted February 21, 2020 Author Share Posted February 21, 2020 wow, you are amazing! can you tell me how you did it, step by step? Do you tutor? Link to comment Share on other sites More sharing options...
amaliya Posted February 21, 2020 Author Share Posted February 21, 2020 Thanks so Much!!! I really appreciate your help! Link to comment Share on other sites More sharing options...
Mark3D Posted February 21, 2020 Share Posted February 21, 2020 I don't like typing so no can't give details of every step, but do often help people with specific problems and that is a good way of learning by screen sharing look and play with that model it will need a bit of correcting probably and there free training on youtube and chief has some good videos Link to comment Share on other sites More sharing options...
amaliya Posted February 21, 2020 Author Share Posted February 21, 2020 ok fare enough, thanks! Link to comment Share on other sites More sharing options...
Mark3D Posted February 21, 2020 Share Posted February 21, 2020 I have done a video trying to desribe how i did your terrain it might help you understand 1 2 Link to comment Share on other sites More sharing options...
amaliya Posted February 22, 2020 Author Share Posted February 22, 2020 Thank you so much! Link to comment Share on other sites More sharing options...
builtright3 Posted February 22, 2020 Share Posted February 22, 2020 18 hours ago, Mark3D said: I have done a video trying to desribe how i did your terrain it might help you understand Great video Mark! 1 1 Link to comment Share on other sites More sharing options...
amaliya Posted February 22, 2020 Author Share Posted February 22, 2020 Terrain, roofing and arched ceilings are my weakness Link to comment Share on other sites More sharing options...
amaliya Posted February 22, 2020 Author Share Posted February 22, 2020 weaknesses* Link to comment Share on other sites More sharing options...
Mark3D Posted February 22, 2020 Share Posted February 22, 2020 3 hours ago, amaliya said: Terrain, roofing and arched ceilings are my weakness You would not be the only one they are hard for most when learning 1 Link to comment Share on other sites More sharing options...
builtright3 Posted February 22, 2020 Share Posted February 22, 2020 18 minutes ago, Mark3D said: You would not be the only one they are hard for most when learning Mark, Can you tell me what the cause of this dark are is? How I might best eliminate it? Link to comment Share on other sites More sharing options...
Mark3D Posted February 22, 2020 Share Posted February 22, 2020 Not sure chief can have trouble with things like that you could try lowering terrain smoothing or check your elevation data if you like post your plan and I can look and try to spot what is doing it Link to comment Share on other sites More sharing options...
Kbird1 Posted February 23, 2020 Share Posted February 23, 2020 On 2/21/2020 at 1:47 PM, Mark3D said: I have done a video trying to desribe how i did your terrain it might help you understand Nicely done Video Mark , you may want to consider putting it in the Tips Forum for General Terrain help for others new to doing Terrains. And to the OP......It is generally accepted you put your Terrain Perimter on Level 1 , so calculating heights is easier. M. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 23, 2020 Share Posted February 23, 2020 18 hours ago, builtright3 said: Mark, Can you tell me what the cause of this dark are is? How I might best eliminate it? It is quite often where the terrain is "folding" down behind the retaining Wall , adjusting or even adding a Terrain Break and playing with it can help to hide the fold's "edge" inside the retaining wall. I tend to use Foundation walls and add my own Terrain Break ...walls are then edited in elevation for heights etc , as it is rare for a Retaining Wall to follow the ground level exactly at least locally , most R.Walls have a coping stone that is level too. ( convert wall to solid railing and use Wall Cap ) M. Link to comment Share on other sites More sharing options...
amaliya Posted February 24, 2020 Author Share Posted February 24, 2020 I am still having problems with terrain. Maybe these pictures will help. Deck (2).plan Link to comment Share on other sites More sharing options...
amaliya Posted February 24, 2020 Author Share Posted February 24, 2020 I put in all the measurements, and this is what happened. The client wanted a smaller deck, so I changed the size as well, and he wanted a straight staircase. Mark, maybe you know the where exactly the problem is. Would really appreciate it! Thanks so much! Thomas Deck—More measurements.pdf Link to comment Share on other sites More sharing options...
