wjmdes Posted January 21, 2020 Share Posted January 21, 2020 Curious if I am missing something or if this is correct in using the "New Default Sets" that have replaced annosets. No matter what I select under the drop down, it always says "Active Defaults" under Default Set. The name of my Default Set (old anno) will not display. I think I have to open the Saved Plan View Specification to verify what the specific individual Selected Defaults are. Has anyone messed with his enough to clarify this so I know how to address moving forward? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2020 Share Posted January 21, 2020 Tool works exactly like it did before. They just renamed it to Default Sets instead of Annotation Sets for continuity and clarity. It will always say "Active Defaults" unless you either select a specific Default Set or select a group of Defaults that matches a Default Set. 1 Link to comment Share on other sites More sharing options...
wjmdes Posted January 21, 2020 Author Share Posted January 21, 2020 3 hours ago, Alaskan_Son said: Tool works exactly like it did before. Well, it wasn't earlier! Ugghhh, I was so sure I had an issue I had my IT department (my son) load software to record a video. I get home and it is behaving properly. If (or should I say when) I come across it again, I will record it so I can demonstrate I am not losing my mind. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2020 Share Posted January 21, 2020 12 minutes ago, wjmdes said: Well, it wasn't earlier! Ugghhh, I was so sure I had an issue I had my IT department (my son) load software to record a video. I get home and it is behaving properly. If (or should I say when) I come across it again, I will record it so I can demonstrate I am not losing my mind. If you set your various defaults back to EXACTLY what you've show in the screenshot above, what does the Default Set say? I'm just wondering if perhaps one little thing was off. Link to comment Share on other sites More sharing options...
wjmdes Posted January 21, 2020 Author Share Posted January 21, 2020 44 minutes ago, Alaskan_Son said: If you set your various defaults back to EXACTLY Very strange, I cannot replicate this now. Before no matter what (anno/default set) I selected in Currently using, it would revert to say Active Defaults, but all the selected defaults below that were correct for what I was choosing. I will video this if it happens again... Link to comment Share on other sites More sharing options...
wjmdes Posted February 6, 2020 Author Share Posted February 6, 2020 Fairly certain this problem is occurring when I import Layer and Default Sets from my new template into older drawings. It does not allow me to change the Default Set at all until I save, close and reopen. Until then it just says Active Defaults Link to comment Share on other sites More sharing options...
BenPalmer Posted February 6, 2020 Share Posted February 6, 2020 1 hour ago, wjmdes said: Fairly certain this problem is occurring when I import Layer and Default Sets from my new template into older drawings. It does not allow me to change the Default Set at all until I save, close and reopen. Until then it just says Active Defaults Bill, I can confirm that is when I get the same behavior: when importing default sets. Link to comment Share on other sites More sharing options...
SNestor Posted February 6, 2020 Share Posted February 6, 2020 19 minutes ago, BenPalmer said: Bill, I can confirm that is when I get the same behavior: when importing default sets. I'm just guessing...but, if you import an annoset, you may have to go to your plan views and make sure the specific "anno/default" set is specified in the plan view dialog. See picture below. Changing plan views changes my anno/default sets...unless I have a plan view that does not have a specific anno/default set specified (which I don't). Link to comment Share on other sites More sharing options...
BenPalmer Posted February 6, 2020 Share Posted February 6, 2020 Thanks Steve, I'll take a look at that on my next import...probably have one later today. I'll report back. Appreciate the input. Link to comment Share on other sites More sharing options...
wjmdes Posted February 6, 2020 Author Share Posted February 6, 2020 10 minutes ago, SNestor said: I'm just guessing...but, if you import an annoset, you may have to go to your plan views and make sure the specific "anno/default" set is specified in the plan view dialog. See picture below. Changing plan views changes my anno/default sets...unless I have a plan view that does not have a specific anno/default set specified It will not let me choose any other sets until I save and reopen. (See my original post above) Link to comment Share on other sites More sharing options...
SNestor Posted February 7, 2020 Share Posted February 7, 2020 On 1/21/2020 at 7:35 AM, wjmdes said: Curious if I am missing something or if this is correct in using the "New Default Sets" that have replaced annosets. No matter what I select under the drop down, it always says "Active Defaults" under Default Set. The name of my Default Set (old anno) will not display. I think I have to open the Saved Plan View Specification to verify what the specific individual Selected Defaults are. Has anyone messed with his enough to clarify this so I know how to address moving forward? Bill...did a video for you. Not sure I covered exactly what you are having difficulty with. If not...maybe you can expound a bit. Hope it helps... 1 Link to comment Share on other sites More sharing options...
wjmdes Posted February 7, 2020 Author Share Posted February 7, 2020 10 hours ago, SNestor said: Bill...did a video for you. Not sure I covered exactly what you are having difficulty with. If not...maybe you can expound a bit. Hope it helps... Thank you Steve! You have confirmed that I am in fact doing exactly what you are. Next week I will be working on a few older jobs and I will try to pay more attention. I am curious if it makes a difference as to what you import first, Default Sets or Layer Sets. I also had an issue yesterday when recreating some of my commercial default sets (because you cannot import just one default set) that it took it a while to propagate and show up in the drop-down list or in the project browser area. I created it in Default Sets Dialog Box and then went to create my Saved Plan View and it was not in the Drop Down, not sure what went on, but it eventually showed up. I have to create 3 or 4 more defaults sets and then these will all be on my template (rather than scattered between several different plan files) and I will try and document exactly what I did. Link to comment Share on other sites More sharing options...
SNestor Posted February 7, 2020 Share Posted February 7, 2020 47 minutes ago, wjmdes said: Thank you Steve! You have confirmed that I am in fact doing exactly what you are. Next week I will be working on a few older jobs and I will try to pay more attention. I am curious if it makes a difference as to what you import first, Default Sets or Layer Sets. I also had an issue yesterday when recreating some of my commercial default sets (because you cannot import just one default set) that it took it a while to propagate and show up in the drop-down list or in the project browser area. I created it in Default Sets Dialog Box and then went to create my Saved Plan View and it was not in the Drop Down, not sure what went on, but it eventually showed up. I have to create 3 or 4 more defaults sets and then these will all be on my template (rather than scattered between several different plan files) and I will try and document exactly what I did. Bill...I was thinking last night that one difference between what I did and what you stated in your original post was that you had opened and "older" plan...and things did not work. In my example video I was using a new plan created in X12...and then imported my default sets, layer sets and saved plan views into the new X12 plan. That might make a difference....not sure really. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 7, 2020 Share Posted February 7, 2020 23 hours ago, BenPalmer said: Bill, I can confirm that is when I get the same behavior: when importing default sets. Me too. I'm guessing it almost certainly has something to do with the fact that the imported Default Sets did not have a Revision Cloud Default to set. That's why nothing you do will ever match an old default set. Chief probably just recognizes this in fixes it during the initial loading of the plan...which would explain why you have to save and then open the plan again. Link to comment Share on other sites More sharing options...
wjmdes Posted February 7, 2020 Author Share Posted February 7, 2020 I needed to recreate a few new "Default Sets" (wish they had not renamed this), so I exported all my default sets and layer sets from my template, made my project current with those settings. I then created a few new default sets, exported and put back in my template. Everything came up "Active Defaults" until I saved and reopened. So there ya go... Link to comment Share on other sites More sharing options...
