Framing Question Trusses & Rafters
ACADuser
I have a plan with trusses & want to build Deadwood at top of truss & ledgers at the bottom of the truss. See attached
I can not use "Hang Floor Platform" on the wall at this time.
So do I need to add the framing member that attaches to the CMU wall by hand or is there a way to auto-generate?
Below is what is generated when I use "Build Roof Framing". I suppose I could drag the rafters down to the ledger position.
BTW I can not post the plan at this time.
Thanks
