Boxed eaves
cjanderson66
I know this discussion has been discussed before but I am having an issue with the roofs overhangs.  I have not had this issue before as most of the time the Boxed overhangs have worked but not this time.  I have tried everything in the book to make my overhangs boxed and nothing is working.  Any idea why my overhangs will show a boxed overhang?
7 minutes ago, Alaskan_Son said:
Away from my computer, but as I recall, you don’t get boxed eves unless soffits are turned on.  You can turn them on and use a Gap material type though.
Damn, I knew it was something super simple as this.  Thanks Micheal and Joey.  I always forget to click the soffits.
  • 3 years later...
I had this issue as well, affecting a false gable dormer (manually built dormer placed over roof-intended to be unseen from interior just to match the rythm of other dormers) but the remedy above did not work, as well as the other suggestions...
I was able to fix the issue by adjusting/lengthening the handle of the roof baseline itself.
