capitaldesigns
Changing dimension text
How do you change individual dimension text in a dimension line. I have a dimension string that has a lot of smaller dimension like 1'-1", 1'-2" and 1'-3".
They are writing over each other. I was told that there is a way to change individual dimensions where I could change them to read 13", 14" and 15".
This way they will not be placed on top of each other. Does anyone know how to do this ?
Thanks,
Mike
You can stagger the dimensions so they don't overlap but I believe you will need to add an extra string to change the formatting.
A couple of years ago someone told me an easy way to change a single dimension in a string.
I should of wrote it down. I haven't needed do to this until now. I forgot how to do it.
If you remember let me know as I am not sure it is possible in X11 or any previous version without a text overlay maybe.
Open the dimension string and on the Primary Format panel, uncheck Use Default Formatting and change Format > Units to inches.
Remember this one Mike ?  It was a while ago but same situation now I think.
    28852
    CPDesigns
    CPDesigns
