wjmdes Posted December 2, 2019 Share Posted December 2, 2019 I was hoping there might be a workaround to save this as a Library Object similar to using the "Shift Key" for text boxes. I think I am just going to have to save it as a .plan file and copy/paste. Is there something I am missing? Demolition Schedule.plan Link to comment Share on other sites More sharing options...
tommy1 Posted December 2, 2019 Share Posted December 2, 2019 Why not shift select>block> add to library? A separate plan would be fine too. Link to comment Share on other sites More sharing options...
wjmdes Posted December 2, 2019 Author Share Posted December 2, 2019 9 minutes ago, tommy1 said: Why not shift select>block> add to library? A separate plan would be fine too. Tried that, I have been trying to get better organized and on my list today was to get the demo stuff set up and stumbled on this small (but annoying issue) Link to comment Share on other sites More sharing options...
rgardner Posted December 3, 2019 Share Posted December 3, 2019 Not 100% sure but can you add a poly line box with a hidden line style and block them together then add to your library? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 3, 2019 Share Posted December 3, 2019 Give this a try Bill. Demolition Schedule and Notes Folder.calibz Link to comment Share on other sites More sharing options...
tommy1 Posted December 3, 2019 Share Posted December 3, 2019 7 hours ago, rgardner said: Not 100% sure but can you add a poly line box with a hidden line style and block them together then add to your library? Yes. I have notes and legends and details with boxes around them and have them saved to the library for future use. you can always unblock them when bringing them in to your plan or cad detail for editing. I do this in almost every plan. Link to comment Share on other sites More sharing options...
wjmdes Posted December 3, 2019 Author Share Posted December 3, 2019 17 minutes ago, tommy1 said: Yes. I have notes and legends and details with boxes around them and have them saved to the library for future use. you can always unblock them when bringing them in to your plan or cad detail for editing. I do this in almost every plan. If there is a trick to get Chief to include the actual notes on the right, next to the schedule, please share. I have drawn boxes, used the "shift" trick to no avail. When the schedule AND the actual notes are selected, Chief will not let me make a block or library item. Link to comment Share on other sites More sharing options...
tommy1 Posted December 3, 2019 Share Posted December 3, 2019 You're using a "note schedule" which I'm assuming is why you can't block it and save it. I don't use the note schedule. I do mine only using text and polylines. This way you can block it and save it. Link to comment Share on other sites More sharing options...
tommy1 Posted December 3, 2019 Share Posted December 3, 2019 BTW, an option would be to do a "cad detail from view". Then you could make it easier to work with in the cad detail>block it and save it it to your library. Just tried it and it works. Link to comment Share on other sites More sharing options...
