DougDM Posted November 23, 2019 Share Posted November 23, 2019 Isn't there a tool where we were able to touch on an object and it would switch to that particular layer. Not the CAD tool where you have to open it and select the layer you want to draw on. Same concept but a tool specifically for doing this. Yes I want CA to switch to selected layer just by selecting an object residing on the wanted layer. I though we had this. Or am I thinking AutoCad. Thanks Doug Link to comment Share on other sites More sharing options...
parkwest Posted November 23, 2019 Share Posted November 23, 2019 Are you looking for saved plan views? Link to comment Share on other sites More sharing options...
Dermot Posted November 23, 2019 Share Posted November 23, 2019 Have you tried using the Layer Painter and Layer Eyedropper tools? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 23, 2019 Share Posted November 23, 2019 On 11/23/2019 at 5:20 PM, Dermot said: Try using the Layer Painter and Layer Eyedropper tools. Expand That maybe the Tools you need ? https://www.chiefarchitect.com/support/article/KB-00645/reassigning-several-objects-to-a-specific-layer.html Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 23, 2019 Share Posted November 23, 2019 On 11/23/2019 at 1:37 PM, DougDM said: Isn't there a tool where we were able to touch on an object and it would switch to that particular layer. Not the CAD tool where you have to open it and select the layer you want to draw on. Same concept but a tool specifically for doing this. Yes I want CA to switch to selected layer just by selecting an object residing on the wanted layer. I though we had this. Or am I thinking AutoCad. Thanks Doug Expand It sounds to me like you're asking for a tool where you can... Click on an object with an eyedropper sort of functionality in order to pick up that object's layer Draw or place another object and have that object get placed onto the layer of the previously selected object. Is that correct? If so, no. There is no such tool in Chief. I would suggest you just adjust your workflow to more efficiently and effectively utilize Active Defaults and Plan Views. Click on Help and search Multiple Saved Defaults. Link to comment Share on other sites More sharing options...
