GeneDavis Posted October 16, 2019 Share Posted October 16, 2019 Some codes require headers be laterally braced by being plated with flatwise members at both top and bottom. If the header is up tight to the top wall plate, no top plate is required atop the header. This, whether the wall is an exterior one or interior. When Chief builds framing for me, it puts my specified number and sizes of plies of headers above openings, but does not place the required plates. Am I missing something in either wall settings or framing settings or window or door framing settings? Link to comment Share on other sites More sharing options...
Chopsaw Posted October 16, 2019 Share Posted October 16, 2019 No you are not missing anything. The only condition that you describe above that chief will currently do automatically is place the header up tight against the top plate provided you have calculated the window position to correspond to that. Otherwise search out one of our previous suggestions or even better start your own. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 16, 2019 Share Posted October 16, 2019 It can be done manually in your wall detail but is not very user friendly. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 16, 2019 Share Posted October 16, 2019 Unfortunately as yet Chief has not updated the way Headers build although it has been "Suggested" and discussed a few times over the Last few years.... maybe time to bump these up again..... https://chieftalk.chiefarchitect.com/topic/12644-more-versatile-header-framing-controls/?tab=comments#comment-108798 https://chieftalk.chiefarchitect.com/topic/16473-chief-built-framing-assemblies/ Link to comment Share on other sites More sharing options...
