word wrap on room labels
madcowscarnival
I had no luck on the first page of google results.  Is it possible to force a word wrap on a room label without simply manually placing text?
Bonus question: how can I place a standalone backsplash behind an oven, below a vent hood?  I see the option for "custom backsplash" but it is not selectable in the menu.  I can just dropper match the adjacent, but that applies to the entire wall.  I have not investigated further, just out of curiosity.
You can also use a material Region and in a pinch use a base cabinet set to 3/4" depth and slide the Range against it.
Sorry not sure about the Room label Text Wrap.....
If you simply put a Text Box in a Room with the %room.name% macro in it (or whatever other text you want) then you can word wrap simply by changing the width of the text box.  The text can also be multi-line and formatted as you like.
You will probably want to "suppress" the actual Room Label.
Another nice feature of using a Text Box is that you can put it outside the Room and connect with an Arrow.  The macro will display the data.
  • 2 years later...
