kwhitt Posted September 26, 2019 Share Posted September 26, 2019 I finished a layout and decided later that I want to show a reference layer showing existing conditions underneath the proposed plan. My layout will not automatically update and the DBX is grayed out. I did not send over from layout as an image - it should be live. Why isn't it updating? Thanks. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 26, 2019 Share Posted September 26, 2019 42 minutes ago, kwhitt said: Why isn't it updating? Thanks. By adding a reference layer you have modified the saved plan view "Working Plan View." You will either need to save the plan view or if you switch to a different saved plan view CA will prompt you with a dialogue on whether you would like to save the modified plan view. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted September 26, 2019 Author Share Posted September 26, 2019 Thanks Rene - Is there a button to save the Working Plan View in its current state? If so, I cannot find one. Link to comment Share on other sites More sharing options...
kwhitt Posted September 26, 2019 Author Share Posted September 26, 2019 Never mind. I found it. Thanks for the help! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 26, 2019 Share Posted September 26, 2019 Just FYI, you can also simply disconnect the layout box from any Plan View by selecting “None” in that dropdown. Then you can modify whatever you want and even optionally create a new Plan View from that. 1 Link to comment Share on other sites More sharing options...
Dermot Posted September 26, 2019 Share Posted September 26, 2019 You should probably not send the Working Plan View to layout. Not unless you want to have to unlink every layout box afterwards. Generally, it is better to create new saved plan views for every unique view you want to send. More information about saved plan views can be found here: https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html And some more general information can be found here: https://www.chiefarchitect.com/videos/playlists/100/20-saved-plan-views-layers-annotations.html 2 Link to comment Share on other sites More sharing options...
kwhitt Posted September 26, 2019 Author Share Posted September 26, 2019 Quote Thanks again Michael. Dermot - I appreciate the link. Will look at that tonight. Link to comment Share on other sites More sharing options...
