robdyck Posted September 20, 2019 Share Posted September 20, 2019 There must be a way to alter or control the vertical spacing of schedules. I've included the exterior elevation view of windows in my schedule, and there's a lot of wasted space between each row. Does anyone know if that can be adjusted? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 20, 2019 Share Posted September 20, 2019 May or may not be an acceptable solution for your situation, but you can try unchecking Scale Images in the Window Schedule dialog Link to comment Share on other sites More sharing options...
robdyck Posted September 20, 2019 Author Share Posted September 20, 2019 3 minutes ago, Alaskan_Son said: May or may not be an acceptable solution for your situation, but you can try unchecking Scale Images in the Window Schedule dialog Tried that. Each unit fills it's allowable space better, but the wasted space remains the same. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 20, 2019 Share Posted September 20, 2019 4 hours ago, robdyck said: Tried that. Each unit fills it's allowable space better, but the wasted space remains the same. The height of those rows in controlled by the width of the column. If you make that column narrower, the rows will have less wasted space. Link to comment Share on other sites More sharing options...
robdyck Posted September 20, 2019 Author Share Posted September 20, 2019 1 minute ago, Alaskan_Son said: If you make that column narrower, the rows will have less wasted space. That's the extent of the control that I found. I changed the name. Would you agree that there's a fair bit of wasted space between rows? I'd like the sliders to control rows like there are for columns. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 20, 2019 Share Posted September 20, 2019 1 minute ago, robdyck said: That's the extent of the control that I found. I changed the name. Would you agree that there's a fair bit of wasted space between rows? I'd like the sliders to control rows like there are for columns. Ya, I definitely agree that we oftentimes have quite a bit of wasted space. It would be nice to see a bit more control in this area. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 21, 2019 Share Posted September 21, 2019 Rob you may need to shorten your column heading a little more or allow it to use two lines so the other rows will take less space. Link to comment Share on other sites More sharing options...
