Sign on Exterior of building
kaclason
You can create a p-solid for the board and apply an image as a material or you can bring your design in as a PDF and trace over it with p-solids to create text and design in 3D or even better bring it in as DWG so you have snap points.  There is also a method of creating a design and saving it a PDF then converting to DWG to avoid the tracing step so you can then convert the DWG components to p-solids.
