AbeLopez Posted July 31, 2019 Share Posted July 31, 2019 What is the best way to add a guardrail on top of sloping wall? Link to comment Share on other sites More sharing options...
rlackore Posted July 31, 2019 Share Posted July 31, 2019 One method is to use ramps. After the shape of the wall is set, draw ramps and manipulate the settings as required. In this example I have two ramps, one for the horizontal section of wall, and another for the sloped section of wall: It can be difficult getting the ramp heights set properly - the ramp dialog isn't very friendly - but once you understand the basics it goes quickly. Link to comment Share on other sites More sharing options...
Evolution Posted July 31, 2019 Share Posted July 31, 2019 1 hour ago, rlackore said: One method is to use ramps. After the shape of the wall is set, draw ramps and manipulate the settings as required. In this example I have two ramps, one for the horizontal section of wall, and another for the sloped section of wall: It can be difficult getting the ramp heights set properly - the ramp dialog isn't very friendly - but once you understand the basics it goes quickly. Could you use railing walls, or perhaps fence? Link to comment Share on other sites More sharing options...
rlackore Posted July 31, 2019 Share Posted July 31, 2019 27 minutes ago, Evolution said: Could you use railing walls, or perhaps fence? I don't know about a fence. I'm not sure you can get a railing wall to follow a slope. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 31, 2019 Share Posted July 31, 2019 I did this is X11 using a fence - follow terrain using a custom "panel" I made using a polyline solid and a railing object from the Library Browser. DJP Link to comment Share on other sites More sharing options...
