Garreth Posted September 26, 2014 Share Posted September 26, 2014 Good afternoon chiefers, question regarding sending an elevation view to layout in chief X5. Presently I send elevation views to layout and get a black and white view ...ok However I like to distinguish between the building outline and the wall patterns. So to do this ...after sending the view to layout I have to adjust the pattern line default colour to grey by opening the layout box specification. What I would like to know if there is a default that I can change which automatically adjusts the pattern line colour to the desired colour in this instance grey when I send elevation views to layout. thanks Garreth Babic Shed Layout.layout Babic Shed.plan Link to comment Share on other sites More sharing options...
dshall Posted September 26, 2014 Share Posted September 26, 2014 Yes, in material dbx Link to comment Share on other sites More sharing options...
Solution Garreth Posted September 26, 2014 Author Solution Share Posted September 26, 2014 Hi D.Scott I have heard of this code but I cannot find any reference to material dbx in the manual? Can you show me where to look .. thanks Link to comment Share on other sites More sharing options...
dshall Posted September 26, 2014 Share Posted September 26, 2014 use the rainbow tool a click on material, the dvx will open up. dbx=defaults box Link to comment Share on other sites More sharing options...
lbuttery Posted September 26, 2014 Share Posted September 26, 2014 dbx=defaults box ummm.... dbx = dialog box Lew Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 26, 2014 Share Posted September 26, 2014 You can change the material-pattern lines where Scott says. Then you don't have to change each layout view. Link to comment Share on other sites More sharing options...
