sweetmelissa Posted July 2, 2019 Share Posted July 2, 2019 I need 2 hinges on my upper cabinet instead of the default 3. I need the hinges to be the "decorative hinge" from the core catalog. I tried to place them manually, but can't seem to make that work. Is there a way to make this happen? Thank you. Link to comment Share on other sites More sharing options...
ShaneK Posted July 2, 2019 Share Posted July 2, 2019 Cabinet Gurus will be chiming in soon,,,,,,, until then where did it tell you 3 hinges were default? Link to comment Share on other sites More sharing options...
sweetmelissa Posted July 2, 2019 Author Share Posted July 2, 2019 1 minute ago, ShaneK said: Cabinet Gurus will be chiming in soon,,,,,,, until then where did it tell you 3 hinges were default? I just assumed 3 was default because that's how many are there and I see no way to change it through the cabinet specifications. Link to comment Share on other sites More sharing options...
ShaneK Posted July 2, 2019 Share Posted July 2, 2019 I see no hinge options at all anywhere in cabinet dbx,,,,,,,, only option is off set from top or bottom. BUT I'm sure someone has a work around and will chime in soon. Link to comment Share on other sites More sharing options...
MarkMc Posted July 2, 2019 Share Posted July 2, 2019 AFAIK cabinets are hard wired to have 3 hinges if the height is greater than 39" (many makers have 3 at 39") To change it visually you need a door symbol with two hinges and no knob or handle. Set cabinet to have hidden hinges. The bounding box and origin need to be adjusted. Made this one from a 15" cabinet. When turning into a symbol the bounding box wants to be 15 5/8 which includes the hinge. Changed BB to 15" then offset the X origin by 5/16 to center the box on the door, set the stretch zones so rails, stiles and hinges don't change when resizing. For some reason that I don't understand it needs to be made with hinges on the right to work properly. (Open Symbol and see what's going on, then go to videos or reference manual for more on symbols) IF you need to change the hing quantity in the material list that gets done in the components tab. I included a simple macro that does that. It's in the two cabinets on the far left in the plan (not in the picture) one of which I set to default. You can do something similar to change the notation for hidden hinge if need be but only if you are serioulsy using the ML. Two hinge door.plan Link to comment Share on other sites More sharing options...
sweetmelissa Posted July 2, 2019 Author Share Posted July 2, 2019 Thank you Mark, I will work on that when I have a bit more time than I have now. Unfortunately, I haven't upgraded to X11 yet (trying to finish up a few jobs before I confuse the situation) so I can't open the plan you attached. I'll try to go off your instructions though and see what I can do. Maybe I will just make a note that there will only be 2 instead of 3 hinges on the layout if it proves to be too time consuming or difficult. Link to comment Share on other sites More sharing options...
MarkMc Posted July 2, 2019 Share Posted July 2, 2019 47 minutes ago, sweetmelissa said: I haven't upgraded to X11 yet I didn't notice that since I often check here on my phone which doesn't show sigs and I tend to assume folks are up to date. Didn't' see that you were on X9 until I redid it in X10. Ah well. Sorry I only have 9 on my 2 in 1 and likely taking it off of there. In any case since I went ahead with it FWIW you can ease into new things in X11 -worth the time and effort IMO. X10 2 hinge.plan 1 Link to comment Share on other sites More sharing options...
sweetmelissa Posted July 3, 2019 Author Share Posted July 3, 2019 21 hours ago, MarkMc said: FWIW you can ease into new things in X11 -worth the time and effort IMO. X10 2 hinge.plan Yours worked great, but I needed a framed door style. It took me about 20 tries, but I finally got it. And, I upgraded. Wasn't as hard as I thought it would be! You are so helpful. Thank you! 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 3, 2019 Share Posted July 3, 2019 Melissa, if you upgraded to X11, please update your signature; that will help tremendously down the road for future help. Thanks, Mike Link to comment Share on other sites More sharing options...
MarkMc Posted July 4, 2019 Share Posted July 4, 2019 On July 3, 2019 at 11:06 AM, sweetmelissa said: but I finally got it. And, I upgraded. Way to go,ets easier with practice. Tip for getting used to new version : the PDF of the Reference Manual lists "what's new ". Each new feature listing has link to its page in the manual. Might want to get both X 10 & 11 manuals since there's been a lot. I still use that section Link to comment Share on other sites More sharing options...
