WHERE THE HECK ARE THE WINDOW/DOOR HEADER DEFAULTS?
Renerabbitt
I've used the search tool and searched the forums and can't figure this one out.
Up until now I've used a custom window/door macro that called out headers...decided to switch to the framing labels and, welp, take a look:
the window shows "4x12" as I like, the doors show "11-1/8 "even though the spec'd deflt is 11-1/4. my door default for that door is set to auto calc based on width, same as the window, yet I have two very different labels even though both use defaults....AND WHERE THE HECK ARE THE DEFAULTS??!! I can't find header label defaults anywhere, somehow they are different labels even though they are identical framing members
53 minutes ago, Chopsaw said:
Framing > Openings.    Looks like quite a mess Rene.  Hope you can get it straightened out.
Is it possible the Wall Detail got tweaked ?
thank you for that, still can't figure out why the member size is the same but the window header reports a 4x12!
Can't seem to duplicate with my test plan.  Are you sure the door and two lower window header labels are actually automatic ?
The 4 x 12 is the nominal size and that seems to be the way the Automatic Label is set up just the way it was a few versions ago when we asked for more control.
You must have %Formatted Depth% in there for the door somewhere.
Post a sample plan file and I will have a look.
Might have to do with the top RO forcing the the header up and reducing the actual dimension? These are both set at 11 1/4 in the door DBX
bingo...this originated as someone elses plan and they had some very strange RO defaults for the hinge doors only..thank you, that was a new one for me
    30418
    louisewman
    louisewman
