LeeDrafter
Hello,
My "My Documents" folder on my work computer is actually on our server, and I know CA is not meant to be used over a network. I would like everything Chief Architect uses "My Documents" for to go in a different folder. How do I re-direct everything that references "My Documents"? I have started a folder on my hard drive called "CA My Documents" and was hoping to use that as the replacement folder. I have already moved all the CA files and libraries that I can find, but chief seems to look for that My documents folder sometimes.
Thank you,
Lee
X10
45 minutes ago, LeeDrafter said:
Hello,
Thank you,
Lee
X10
folder preferences are in edit/preferences/general/folder/
Thank you Rene, I was able to change almost all of those to my hard drive. But when I clicked "Show" all program paths, the bottom program path is still set to "My Documents", and I don't know how to change it. A snip is attached.
Thanks,
Lee
Thanks,
Lee
Chief normally stores all the User Files in the Chief Data Folder which it usually keeps in My Documents, if you are worried about it being on your Server I wouldn't be keeping my Data Folder on OneDrive either. Keep it local and back it up to OneDrive instead.
  • 3 weeks later...
Thank you, the one drive folder is within the hard drive, then it gets backed up to the one drive cloud. So I think we are ok there.
I am wondering if I can change the path to "my documents" to refer to a different folder. My work server is set up so that all computers' "my documents" folders are on the server. I think Chief automatically looks for "my documents" for certain things. I am hoping to change that to a different file location that is not on my server. I read an article this morning that lead me to believe this is possible in version X11, but maybe not previous versions. Is that right?
On 6/19/2019 at 8:07 PM, BrownTiger said:
This is difficult to tell, where could the settings be ... they could be just anywhere .... :)
C:\Users\<user>\AppData\Roaming\Chief Architect Inc\Chief Architect Premier X10.ini
Thank you! I had to take a 2nd look at your post, but I think we can re-direct things now that you pointed out that ini file.
FYI Chief locating the My Documents Folder is simply that, it locates the folder for default settings which would store data at that location. As soon as you relocate your Data folder CA no longer looks to your My Docs folder...there is no need to mess with it
The original post is old news now but...  I've never not used CA over a server for file storage.  At the office its unnoticeable, plenty of high-speed transfer.  At home office I now connect via VPN to that server (rather than a mapped cloud drive).  Its a little slower opening, and saving, but other than that no problem.  I have had situations where I forget to close out a file one evening, VPN logs out automatically the next day, get back to the program that evening, log in again, and no issues with corruption etc.
There is not much magic to this... Chief reads that ini file for all locations.
User%20Settings%20Folder=C:/Users/<BT>/OneDrive/Documents/Chief Architect Premier X11 Data/
Shared%20System%20Library%20Database%20Folder=C:/ProgramData/Chief Architect Premier X11/
Manufacturer%20Data%20Path=C:/ProgramData/Chief Architect Premier X11/Manufacturer Data/
    30404
    willmick
    willmick
  • Similar Content
    • By AlamoChief
      I am setting up a new computer and have downloaded Chief X12. What is the best way to transfer all my data, libraries and templates? Also how to I load all the bonus content, can it be transferred or do I have to download each library again from Chief website? FYI when I installed Chief it didn't create an X12 data folder so I copied it from my old computer. I also have the downloaded libraries in my download folder so I could copy them and open them one at a time I suppose. I just don't want to have a zillion duplicate files and textures like I have had in the past when migrating upgrades. Thanks
    • By Kbird1
      In case you missed it :
      https://www.chiefarchitect.com/blog/computer-for-design-and-gaming/
    • By Dougak
      is there a preferred model or does it matter Laptop vs desktop?  I have outgrown my laptop, x12 crashing and I am experiencing a lot of lag...
    • By Clemson_Causey
      So this is more just an FYI, but my current IMac that I use does not support X12 due to older video card and older OS system.  So was looking to get a NEW computer and have loved the reliability of the IMac, but was frustrated the the latest IMacs that were just released still had subpar video cards.  So have been doing a lot of research with Chief Architect Help Desk, Apple, and other PC manufacturers like Dell/HP and just wanted to share in case any other Chief Users out there were looking to invest in a New Mac.
      The end result is this: the current AMD Pro Vega video card in the 2019 IMacs will run Chief X12, but Chief is moving towards all their platforms using "ray-tracing" video cards that support Direct X, or the Metal platforms.  The Nvidia RTX 2080ti card is one of the best cards on the market to support the Direct X platform and ray tracing.  However, Apple only uses AMD chips at the time.  (and yes you can use add on hardware that reads the Nvidia card, but not looking to invest $3800 in a new IMac, and then have to use an EPU to get the graphics correct).  So Chief advised that IF I wanted to stay with Apple products, they advised waiting until later this year to see if AMD and Apple's new releases will have the "Metal" platform on their graphics cards, which will support future versions of where Chief is headed.
      Therefore, although I hate not upgrading and using X12, and I considered switching to a PC, which are very good, I decided to wait it out and see what Apple does later this year with their upgrades and newer video cards with AMD.  Here is a link to explain more of the Metal platform that Apple is using. https://developer.apple.com/metal/
      Since I had done so much research, just wanted to share with anyone who was looking to get a new Mac this year.  Again, current Macs will support and run Chief great, I just wanted to make sure that when I invest in a new computer, that it will still run Chief upgrades well 2-3 years from now.  Hope this helps!
    • By glipovsek
      Chief architect works great on my work computer and my home laptop. However, when I VPN from my home laptop to my work computer, Chief freezes on the start up screen. We work all of our chief files from a server at the office. I can access and work on anything else from the server, but chief always freezes up immediately. What can fix this? Faster internet upload/download speeds? Something else? THANKS in advance!
