how to change flooring name?
Gopalkatari
when i was open chief architect file in 3ds max. it shows all floors in a single naming only.like flooring 1, flooring 2.but i want flooring name as per i build.
example:in bedroom i want flooring name bedroom.in kitchen i want flooring name kitchen.
5 hours ago, DRAWZILLA said:
just copy the material and change it's name
It may not be quite that simple Perry.   I have a similar issue with exported Collada files that I am trying to figure out.  Collada just assigns what seems to be a random number to each material in the file.  Even if there was some logic to the sequence it would be helpful.  I have asked tech support and they have no idea.  So it is interesting that someone moved the posting and did not bother to try to address the issue as I am pretty sure there is someone at Chief Architect that knows about this, or at least there should be.
