BethVanDeusen Posted May 27, 2019 Share Posted May 27, 2019 I installed X11 about a week ago and everything seemed fine - until today. When logging on I got a message that my video card could not handle advanced lighting techniques (I think?) and now my perspective full overviews are messed up. The thing is, it's been fine until now. Did I inadvertently change something in the settings? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted May 27, 2019 Share Posted May 27, 2019 If it was working ok with X11 the other day then it might be something in that plan that is causing the problem. Try another plan to see if it happens again. You could also post that plan so we could see if we also get that message. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 27, 2019 Share Posted May 27, 2019 I would suggest looking into the Nvidia Drivers , looks like you have an older laptop and Nvidia 296.88 is several years old ( current is 430.86) and there have been issues with older Nvidia Drivers. Not sure what Nvidia Card you have though from your Signature?. It's also possible that X11 didn't switch the GPU to the Nvidia Card ( Optimus) and that you are actually using the built in Intel GPU , the Render TAB in Preferences should tell you that. https://chieftalk.chiefarchitect.com/topic/17190-inserting-object-from-library-browser-freezes-most-of-the-app/?do=findComment&comment=144430 M. Link to comment Share on other sites More sharing options...
Dermot Posted May 28, 2019 Share Posted May 28, 2019 This is most likely the result of a video card or driver problem. See this help article for more information about video card problems: https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html If all else fails, then you might want to try contacting our tech support team. Link to comment Share on other sites More sharing options...
BethVanDeusen Posted June 6, 2019 Author Share Posted June 6, 2019 Thank you for the replies. I did update my Nvidia driver and everything seems to be working better. Link to comment Share on other sites More sharing options...
