Dennis_Gavin Posted September 23, 2014 Share Posted September 23, 2014 Is it just me (probably) or has the default edit behavior for the mouse changed? I find the right mouse button is now acting like the left one and visa versa. I changed to alternate behavior from default and now it is OK. I don't remember having the preference as alternate before the latest update. Has it always been this way (probably)? Am I losing my mind one little gray cell at a time? Thought alt behavior changed things but not. Why has my mouse behavior changed out of the blue?????(rhetorical) I have not installed any new/updated drivers. WEIRD........ Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 Also, I use to be able to resize text by holding down the "x" key and re-sizing it. It doesn't work that way anymore. You now must click the re-size default then re-size the text, they have added another 2 clicks--not good. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 23, 2014 Share Posted September 23, 2014 Also, I use to be able to resize text by holding down the "x" key and re-sizing it. It doesn't work that way anymore. You now must click the re-size default then re-size the text, they have added another 2 clicks--not good. Works for me - select text, press and hold "x", drag corner of text. What are you doing different? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 Joe I don't know, it doesn't work for me. Do you have the" re-size default behavior" checked or just "Default behavior" checked? I have just "Default" behavior checked. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 Dennis, what mouse? I have Logitech performance MX Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 23, 2014 Author Share Posted September 23, 2014 Perry - it's a Logitech wheel mouse. Not sure of the series. I wonder if it has anything to do with the buttons on the side. Maybe I clicked one not knowing it and caused the changes. I will mess with it and see if anything changes. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 My re-size text problem has been solved . Screwing with hotkeys was the culprit. I tried it,now ,no hotkeys for me. Reset--done. Dennis, You could reset to factory settings or what I've done in the past, just use the generic Microsoft drivers. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 23, 2014 Share Posted September 23, 2014 Here's what I have as my defaults Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 Thanks Joe. Link to comment Share on other sites More sharing options...
