brianhf Posted April 22, 2019 Share Posted April 22, 2019 I'm having a problem getting the exterior wall to build correctly on the second floor. It appears it's related to a first floor wall, as the material finish changes to align below. Could this be a platform build issue? Greatly appreciate some help. This plan is a work in progress, so please ignore the other problems. Thanks, Brian. Bent creek 9.plan Link to comment Share on other sites More sharing options...
NRST8TRKR Posted April 22, 2019 Share Posted April 22, 2019 Brian, Are the first floor ceilings supposed to be the same or did you intend them to be different? Looking for a starting point. Ken Link to comment Share on other sites More sharing options...
brianhf Posted April 22, 2019 Author Share Posted April 22, 2019 All of the first floor ceilings are supposed to be the same. 108" Thanks. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted April 22, 2019 Share Posted April 22, 2019 Ok ,I noticed ceiling different and Floor levels different on second floor. I'll see what I can come up with. Ken Link to comment Share on other sites More sharing options...
brianhf Posted April 22, 2019 Author Share Posted April 22, 2019 the program keeps changing the first floor ceiling heights for some reason. Scratching my head on this one. Link to comment Share on other sites More sharing options...
Evolution Posted April 22, 2019 Share Posted April 22, 2019 Brian, did you set up your ceiling height for the first floor of 108" by "Edit>Default Settings>Floor 1 Defaults" or did you do it room by room. Link to comment Share on other sites More sharing options...
brianhf Posted April 22, 2019 Author Share Posted April 22, 2019 I initially set first floor ceilings by default settings, floors and rooms,current floor. all to 108 Link to comment Share on other sites More sharing options...
Mark3D Posted April 22, 2019 Share Posted April 22, 2019 not sure what is causing it but editing the wall in 3d fixes it Link to comment Share on other sites More sharing options...
brianhf Posted April 22, 2019 Author Share Posted April 22, 2019 thanks i'll try that thanks for response Link to comment Share on other sites More sharing options...
NRST8TRKR Posted April 22, 2019 Share Posted April 22, 2019 Brian,, Not sure if the room to the right of the bathroom on the second floor is supposed to be a full 96 inch high room or an attic. You need start on the second floor name the rooms and set room ceiling heights and floor heights then the floor framing defaults then go to the first floor and check the room ceiling heights. I saw in the structure tab you had some floor framing at 18" and some as something else. Get floors and ceiling correct then you can start on correcting the roof. Not sure what your intentions are so that is as far as I can go. A wall from the first floor was generating an attic wall that was conflicting with the wall on the second floor that was your first concern. Hope this gives you some help' Have a great week ,Ken Link to comment Share on other sites More sharing options...
braneks Posted April 23, 2019 Share Posted April 23, 2019 Brian, Not sure what Chief's problem was but "fixed" by rebuilding the bedroom 12'3" front wall with the window. Attaching my modified plan (which should look exactly like the original minus the rendering issue). Bent creek 9-braneks.plan Link to comment Share on other sites More sharing options...
brianhf Posted April 23, 2019 Author Share Posted April 23, 2019 Braneks. Thanks for your response. So all you did was rebuild the front dormer wall? As in delete and redraw? Sometimes Chief gets confused - particularly on complicated two-stories. The automatic walls sometimes put themselves in odd places. I very much appreciate your effort and that of all of the other respondents. Brian. Link to comment Share on other sites More sharing options...
