Can't Rotate whole house
KellySantaRosa
5 minutes ago, KellySantaRosa said:
Why is it that when I select the whole house I cannot rotate it?
What method of selection are you using?
assuming you are referring to a house in .plan, can you post a .plan file?
can you demonstrate in a video?
Are you using the Edit Area Tool?
the rotate plan view tool?
