ldharris Posted September 18, 2014 Share Posted September 18, 2014 Hey guys, has anyone ran into this issue yet? A completed projected, clients requested some minor changes. I noticed as I was making these changes (adding French Doors to the family room) and sending to layout, my window casting disappeared and will not display in any view. But this is only on the first level. I've checked all my displays and layers to no avail. I have even tried adding custom 3D molding around the windows. It will shows the custom molding selected but still will not display. I can move the window or custom 3D molding to the upper level and casting will display. Kinda at a loss. Any ideas, anyone?!? Thanks, Larry D Link to comment Share on other sites More sharing options...
Rosco2017 Posted September 18, 2014 Share Posted September 18, 2014 If you attach the plan, I'm sure we can get this figured out in no time. Never had window or door casings disappear unless I accidentally turned them off in the specification dialogue box. I'm stumped at this point. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 18, 2014 Share Posted September 18, 2014 Have you changed the Wall Type? Is it possible the Casings do no project out beyond the Brick? Link to comment Share on other sites More sharing options...
rlackore Posted September 18, 2014 Share Posted September 18, 2014 You may want to check this post: https://chieftalk.chiefarchitect.com/index.php?/topic/1743-recessed-window-casing-brick-walls/?hl=window Link to comment Share on other sites More sharing options...
ebdesign Posted September 18, 2014 Share Posted September 18, 2014 & it's still not fixed even though it is listed as "fixed" in the update notes. Link to comment Share on other sites More sharing options...
tommy1 Posted September 18, 2014 Share Posted September 18, 2014 & it's still not fixed even though it is listed as "fixed" in the update notes. Jim, I just placed 4 brick walls, added a window, made the exterior casing 2" and recessed it. Everything looks okay like it should (it didn't before). I didn't try other different scenarios. Link to comment Share on other sites More sharing options...
ldharris Posted September 23, 2014 Author Share Posted September 23, 2014 No, I haven't changed wall types. Okay, I will try to get this to attach. Link to comment Share on other sites More sharing options...
ldharris Posted September 23, 2014 Author Share Posted September 23, 2014 Hey guys, I went back and read this post (https://chieftalk.ch...alls/?hl=window). For some reason it works. THANKS Rrlackore and thank you all for your suggestions and help. Link to comment Share on other sites More sharing options...
