dskogg Posted March 24, 2019 Share Posted March 24, 2019 i have built a spice drawer but when i make cabinet 6" wide my 4.5" spice drawer disappears, any reason why? Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2019 Share Posted March 24, 2019 Does this one have any effect ? Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 I changed min cabinet size to 2” it didn’t help. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2019 Share Posted March 24, 2019 9 minutes ago, dskogg said: I changed min cabinet size to 2” it didn’t help. You may need Mark to wade in as I am not a Cabinet Guru sorry.... @MarkMc Link to comment Share on other sites More sharing options...
MarkMc Posted March 24, 2019 Share Posted March 24, 2019 35 minutes ago, dskogg said: have built a spice drawer but when i make cabinet 6" wide my 4.5" spice drawer disappears, any reason why? Might have an idea if a plan was here. Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 here is the plan corbel drawer face art2.zip Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 i used a revit shelf spice drawer and same thing happened when i went too narrow Link to comment Share on other sites More sharing options...
MarkMc Posted March 24, 2019 Share Posted March 24, 2019 You have grid snaps turned on in cabinet default and in plan, making the one cabinet 5-3/4" instead of 6" (I never use grid snaps working with cabinets). At 6" it shows back up. It appears 6" is minimum which makes sense to me. The narrowest manufactured PO that go into a cabinet mfg is 4-1/2" (and that has glides on one side only). In wood the narrowest is 5", below that they are filler pullouts. Sure maybe someone could make something narrower to fit into a cabinet box but why. Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 11 minutes ago, MarkMc said: You have grid snaps turned on in cabinet default and in plan, making the one cabinet 5-3/4" instead of 6" (I never use grid snaps working with cabinets). At 6" it shows back up. It appears 6" is minimum which makes sense to me. The narrowest manufactured PO that go into a cabinet mfg is 4-1/2" (and that has glides on one side only). In wood the narrowest is 5", below that they are filler pullouts. Sure maybe someone could make something narrower to fit into a cabinet box but why. Thanks Marc, so you turned off giid snaps in cabinets( i changed it to .5" increments) and turned off grid snaps in plan, but once that is done what did you do? i made door over size so it hangs over cabinet on either side by 3/4" so the drawer hides gables and doesn't look like a drawer, so if i make cabinet 4.5" wide, drawer face will be 6" wide and i will have a drawer that is about 3" wide fit into 4.5" wide cabinet... Did you resave my custom spice drawer with grid snaps in plan and cabinets off? Link to comment Share on other sites More sharing options...
MarkMc Posted March 24, 2019 Share Posted March 24, 2019 I turned snaps off in both, resized cabinet to 6" -may have changed minimum cabinet size or size increments but don't think I did that until I tried to get something narrower than 6". 4 minutes ago, dskogg said: i wwith ill have a drawer that is about 3" wide fit into 4.5" wide cabinet... I wouldn't. Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 This is a cabinet my company made i am trying to replicate. we use 5/8" birch plywood for cabinet boxes Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 Hi Marc, not sure what you did but i turned off grid snaps on plan and in cabs...ca wont show drawer if cabinet is less than 6"... Link to comment Share on other sites More sharing options...
MarkMc Posted March 24, 2019 Share Posted March 24, 2019 7 minutes ago, dskogg said: wont show drawer if cabinet is less than 6"... 1 hour ago, MarkMc said: ears 6" is minimum which makes sense to me.  Link to comment Share on other sites More sharing options...
dskogg Posted March 24, 2019 Author Share Posted March 24, 2019 Thanks, it doesnt make sense for ca not to show drawer below 6" cab width, it it woks it works... A 4.5" cabinet with 5/8" sides will give you a clear 3.25" opening, then you could use top and bottom mount slides and a 3" wide drawer. I thought i was doing something wrong but it looks like ca has chosen not to show drawers in cabinets less than 6" wide when open. Link to comment Share on other sites More sharing options...
MarkMc Posted March 24, 2019 Share Posted March 24, 2019 45 minutes ago, dskogg said: Thanks, it doesnt make sense for ca not to show drawer below 6" cab width, it it woks it works... A 4.5" cabinet with 5/8" sides will give you a clear 3.25" opening, then you could use top and bottom mount slides and a 3" wide drawer. I thought i was doing something wrong but it looks like ca has chosen not to show drawers in cabinets less than 6" wide when open. - then account for the thickness of the drawer sides?. I gave you my opinion.. to me it makes no sense to build it (with or without drawer sides-waste of money and function) so why show it. If you really want to show it make the symbol with the door and corbel on it-lock the dimensions and change the origins then place it as a rollout shelf instead. Link to comment Share on other sites More sharing options...
dskogg Posted March 25, 2019 Author Share Posted March 25, 2019 here is the hood, making the cabinet door on spice rack any wider than 6" makes it too fat... Link to comment Share on other sites More sharing options...
